Wyze Probe question.
  • Killerdx66
  • Killerdx66's Avatar Topic Author
8 years 11 months ago - 8 years 11 months ago #15272 by Killerdx66
Wyze Probe question. was created by Killerdx66
Any of you guys have the Wyze probe? I just bought the 24 inch Wyze probe. Mailman dropped it of yesterday and I was excited to try it out. Got a 2003 F250 5.4 (COP) and 1998 Civic 1.6 (distributor) setting in the yard. First off tried the Honda, worked well on it. I was able to get good wave form on my Verus Edge by holding the prob tip at the distributor cap were the plug wire meets the cap. I could also get a decent but not great waveform at the plug end of the wire. Defiantly worked better at the cap. Now on to the the COP on my 5.4. I was NOT able to get a waveform by holding the tip of the probe flat on top of the coil. I tried every coil with no luck. Not sure if i had it setup wrong but i dont think i did. I used the presets in the Verus. Was set at 15k with a trigger. Cant remember time base.Tried inverting it,no change. Trace was almost a flat line. Its worth mentioning the coils have been replaced in the past. All 8 of them are after market. The cheap ones you get on ebay. Truck runs great i was just playing around with the new prob but it does concern me i couldn't get a waveform. The hard to get to 5.4 coils is why i bought the longer 24 inch Wyze probe. An ideas what went wrong? Maybe the aftermarket coils? I did try it again on the honda after it failed on the ford. I didn't change anything, used the same setup and it worked fine on the honda .
Last edit: 8 years 11 months ago by Killerdx66.
8 years 11 months ago - 8 years 11 months ago #15273 by bruce.oliver
Replied by bruce.oliver on topic Wyze Probe question.
Just go into volts dc on the scope. Set it to 2v and 10ms screen. Try that and adjust your voltage up or down til you get a good capture
Last edit: 8 years 11 months ago by bruce.oliver.
The following user(s) said Thank You: Killerdx66
  • Killerdx66
8 years 11 months ago #15275 by Killerdx66
Replied by Killerdx66 on topic Wyze Probe question.
Thanks bruce. That was it.Looks great at 200mv 10mv.
Thanks for the help.
8 years 11 months ago #15281 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Wyze Probe question.
You find you can find two known good COP from different coil manufacturers on the same vehicle that give completely different secondary primary and secondary waveforms and some COPs are just about impossible to get a secondary from.
  • Killerdx66
8 years 11 months ago #15285 by Killerdx66
Andy.MacFadyen wrote: You find you can find two known good COP from different coil manufacturers on the same vehicle that give completely different secondary primary and secondary waveforms and some COPs are just about impossible to get a secondary from.
I noticed this on a Altima 2.5 once while using my amp clamp. Had two stock coils and two aftermarket coils. The amp ramp was completely different between the stock and aftermarket. The control signal was diffrent as well.
8 years 11 months ago #15286 by Tyler
Replied by Tyler on topic Wyze Probe question.
You'll have much better luck holding the tip of the probe at the very base of the coil, close to the cylinder head, preferably touching the rubber boot. This is where I always find the strongest/cleanest signal.
8 years 10 months ago #15813 by Dtnel
Replied by Dtnel on topic Wyze Probe question.
Great info regarding setup. That's where newbies to scoping lack. If someone were to create a book for scope setup and go over the different types of cop's, coils, coil packs, sensors, waveform settings for various stuff and recommended settings, recommended timebase, etc I'd probably buy the book especially if it was in a reference style format meaning a handy book that one could keep on them, close by , paper format or paper and PDF format for pulling it up.
Would be even better if you select the year, make, model of vehicle and select what you're testing and it automatically sets and has a guided tour for the inexperienced. They'd have less people intimidated by these using them more and getting top notch diagnostics done with man hours saved, shops profitable. One thing would be to have a check mark where one could uncheck a box if they don't want or want the guided tour for setting up.
IF I knew programming I'd be finding me some mastertechs and partnering up and creating a platform to sell to scope mfrs to integrate with their software.
8 years 10 months ago #15820 by bruce.oliver
Automotive Oscilloscope
Your first paragraph sounds a lot like this book. I've heard great things about it and have it on order.
Your second paragraph sounds a lot like snapon scopes. While not perfect their guided component tests can be helpful
The following user(s) said Thank You: Dtnel
8 years 10 months ago #15839 by Andy.MacFadyen
One of the very few disadvantages of virtual scopes that work through a PC or tablet style interface is it takes longer to scroll through the settings, even if the scope has presets it can take a while to scroll to the right one. I mainly use an Owon bench style labscope that can't store many pre-sets but has real knobs you can twiddle very rapidly and has an autoset feature that will set a stable wave form up all on its own.
In the end it all boils down to getting used to the scope and having a rough starting point for screen time and voltage settings from there you can play with the trigger and aquisition settings.
The Pico website guided test pages and videos are always a good guide.
8 years 10 months ago #16210 by Dtnel
bruce.oliver wrote: Automotive Oscilloscope
Funny.you mention that book as I'd broke down and bought it between my post above and today while going thru and looking at replies to threads I'm watching or have commented on. Looks as if it'll be a great read.
8 years 10 months ago #16298 by EricGoodrich
Replied by EricGoodrich on topic Wyze Probe question.
I never set a trigger until I know my scaling is right.
As far as COP probes go, I've seen coils that are so well insulated I can never get a reading. Additionally, the probe is sensitive to placement and pressure against the coil. When possible I like to use extension leads and a capacitive pickup. I feel the results are more consistent.
Sometimes they bury coils so a cop probe is there only practical option. So I do use it sometimes.
