Question about 1st generation modis
  • johnathon.balderas
  • johnathon.balderas's Avatar Topic Author
  • Stay humble and thank God everyday for waking up.
8 years 11 months ago #15194 by johnathon.balderas
Question about 1st generation modis was created by johnathon.balderas
Just recently got 1st generation modis and the battery doesn't last very long. Would it be OK to use the scope while hooked up to the vehicle.
  • Landroverman1958
  • Landroverman1958's Avatar
8 years 11 months ago #15212 by Landroverman1958
Replied by Landroverman1958 on topic Question about 1st generation modis
Hiya, just plug your modis into the 12v supply using the battery supply cable if you have one of course,they do suppy a vehicle battery lead with croc clips so you are able to connect to the cars battery or even a slave 12v supply.
8 years 11 months ago #15226 by Tyler
Replied by Tyler on topic Question about 1st generation modis
Hey johnathon. I've never had an issue using the scope with the OBDII cable plugged in at the same time. :)
The following user(s) said Thank You: johnathon.balderas
8 years 11 months ago #15261 by Noah
Replied by Noah on topic Question about 1st generation modis
The OBD cable will actually ground the scope.
I can remember using my modis with the OBD cable connected, and going to check power at the battery just to check my connections, and a spark jumped from the lead to the battery before contacted it.
Could have been unrelated, but it could have hurt something too.
8 years 11 months ago #15311 by johnathon.balderas
Replied by johnathon.balderas on topic Question about 1st generation modis
Hmm thats a bit scary. I know Paul uses his verus plugged into to the aldl connector often and he never has any issues.
8 years 11 months ago #15349 by GypsyR
Replied by GypsyR on topic Question about 1st generation modis
That's all I use as my battery is completely dead. There apparently are no new batteries. You can get yours "rebuilt" though. Dead batteries bring up to $60 on Ebay (last one I saw)
Battery rebuilders- www.mtobattery.com/blogs/news/snap-on-mo...a0273b05a-rebuilding
