OBD1 scopes
  • Dave101
  • Dave101's Avatar Topic Author
  • Show me what it's not!!
8 years 11 months ago #14835 by Dave101
OBD1 scopes was created by Dave101
Guys,
I work on mostly OBD2 type vehicles but I am starting to get more and more OBD1 cars. I have a Verus Pro scope. My question is.. is it worth the money to buy adapters for my scope to look at OBD1 vehicles or should I continue to count the blinks of the Service Engine Soon lights? I also am wondering can you look at fuel trims on fuel injected OBD1 vehicles?
Thanks for your input
8 years 11 months ago - 8 years 11 months ago #14846 by Chad
Replied by Chad on topic OBD1 scopes
Yes. Get the OBD I adapter. There is not near as much info/capabilities as OBD II, but you CAN read some engine data pids.
Last edit: 8 years 11 months ago by Chad.
The following user(s) said Thank You: Dave101
8 years 11 months ago #14890 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic OBD1 scopes
I would really think hard if tooling up for OBD1 is worth it, these vehicles are already at 20 years old and the numbers on the road will pretty soon fall off the cliff and those that do remain will be in the hands of guys who have their own scantools.
If you do tool up for OBD1 then I would look for secondhand scan tools rather than buy adaptors.
8 years 11 months ago #14894 by Chad
Dave101 wrote: but I am starting to get more and more OBD1 cars
Clearly, you still have a need for OBD-I. I do, as well. Adapters sell for less than $20, each, on Ebay....A whole set for $150.
  • Dave101
8 years 11 months ago #14903 by Dave101
Replied by Dave101 on topic OBD1 scopes
Clearly, you still have a need for OBD-I. I do, as well. Adapters sell for less than $20, each, on Ebay....A whole set for $150.[/quote]
I am looking for attachments that fit my scope, but I am wondering what data pids can you see? And is it worth it?
8 years 11 months ago #14907 by Chad
The pids you get vary. It was up to the Manufacture's discretion.
My personal truck happens to be OBD-1. (1991 Chevy K2500) I'll connect it, tomorrow, and post a screenshot.
8 years 11 months ago - 8 years 11 months ago #14920 by Chad
You asked, specifically, about fuel trim. Block Learn and Integrator are your LTFT and STFT. 128 being Zero. Anything above is positive. Anything below is negative.
8 years 11 months ago #14921 by Chad
8 years 11 months ago #14943 by Tyler
Replied by Tyler on topic OBD1 scopes
GM was fantastic about providing data even in the OBD1 days. :cheer: Always appreciated that.
Dunno how many OBD1 Fords you see, but those adapters are absolutely worth having. Many applications provide data, and even if they don't, being able to do the KOEO Self-Test and KOER Self-Test is worth it all on its own.
1 year 11 months ago - 1 year 11 months ago #67767 by Derf
Replied by Derf on topic OBD1 scopes
Hi,
Apologies for the necroposting on this one, but it seems to be what I'm looking for from the folks with the knowledge.
I am an avid shadetree kinda guy that started way late. I do my own diag and repairs but have never opened up an engine.
Vehicle is a 1995 Saturn SC2 Coupe, 242K. Orig owner.
OBDI (ALDL) diag port, OBDI PCM
Rebuilt engine
I have an old actron 9145 that reads OBDII and OBDI with an adapter cable (Actron).  It accesses and displays quite a bit of data, but nowhere close to what is shown in Chad's post above in the screenshots.
I know every PCM may support different PIDs and that not all are easily accessible without the appropriate diagnostics tools.
I'd love to have access to all of the information shown in Chad's screenshots but I know it is unrealistic to assume any reader can access all of that other than a Tech I or Tech Ii from my Saturn.
Or is there a chance that the Snap-On reader shown in his posts might be able to pull as much as a Tech II?
Not just looking for how many PIDs I can access; obviously I'd like to have the capability of pulling as many as possible as I plan to keep this vehicle alive for many years, and I figure that if I'm going to get a real diagnostic tool for it, now would be a good time as they are starting to disappear.
I am thinking Tech II or Tech II knock off, or a capable snap-on scanner (used) that won't break the bank for a DIYer. As of the time of this post, I believe the snap-on in Chad's pictures is about $300 used if you can find it. And that's without the adapters. I believe a used Tech II setup is about the same.
Ultimately my questions are:
1) does anyone have experience using scan tools to extract OBD1 info from Saturns (S series)?
2) what are your recommendations regarding a specific scan tool to purchase?
3) does the snap-on product in Chad's post come with the software for the PC or is it tool only? Or was he using a different software package, and if so, what is it?
4) Tech II software...extra $$?
Thanks in advance for your assistance.
Derf
Last edit: 1 year 11 months ago by Derf. Reason: Added info
