(Resolved) Picoscope advanced triggers
  • EricGoodrich
  • EricGoodrich's Avatar Topic Author
8 years 11 months ago - 8 years 11 months ago #14751 by EricGoodrich
(Resolved) Picoscope advanced triggers was created by EricGoodrich
I've been using a scope for quite a while but I've never used advanced triggers. I'm in the demo mode and trying to mess around with the advanced triggers but I can't seem to get anything to trigger on the waveform. I've tried pulse width, window, interval etc but can't seem to get it to work. Can anyone help out or point me in the right direction?
The included manual in the software makes sense it's just that the triggers simply aren't working. Thanks.
Last edit: 8 years 11 months ago by EricGoodrich.
  • EricGoodrich
8 years 11 months ago #14752 by EricGoodrich
Replied by EricGoodrich on topic Picoscope advanced triggers
I'm using the Picoscope 6 automotive software and a 4425 scope.
8 years 11 months ago #14762 by bruce.oliver
Replied by bruce.oliver on topic Picoscope advanced triggers
  • EricGoodrich
8 years 11 months ago #14778 by EricGoodrich
bruce.oliver wrote:
Thanks Bruce. I actually watched that very video last night. I'm going to try again today. Thanks for the help!
  • EricGoodrich
8 years 11 months ago - 8 years 11 months ago #14788 by EricGoodrich
I brought my signal generator home so I could do some experimenting. Got it all figured out. Thanks. I had always been able to use a simple trigger but I wanted to be able to utilize as much of the tool as I could. What I'm looking forward to the most is using logic triggers. With logic triggers I can monitor all wires on a sensor, for example, and if any of those values, power, ground or signal drop out, the scope will trigger and stop the waveform. Really awesome.
On a side note, Pico really needs to provide an in depth tutorial on triggers. Not just an overview. I mean, really spend some time on each one. Wasn't very intuitive.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
8 years 11 months ago #14870 by Dylan
Replied by Dylan on topic Picoscope advanced triggers
There's this new channel on YouTube. Got the link from Keith (New level auto). It's called JM Diagnostics. If you like Pico should check it out.
www.youtube.com/channel/UC5IeiZ5hF3RekgKGE2PCHfQ
The following user(s) said Thank You: EricGoodrich
8 years 11 months ago #14874 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic (Resolved) Picoscope advanced triggers
One application I can see is capturing self-test pulse to the wheel sensors when Bosch active ABS wakes up.
