Secondary ignition waveform
10 years 1 week ago #2236 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Secondary ignition waveform
I did a bit of experimentation measuring the actual resisstances of the Hantek HT25 probe with an my trusted Uni-T UT203 meter --- interesting result.
At Scope BNC: + to Ground 33k ohms,
At Pickup: + to Ground 33K ohms
Scope end to Pickup End 0 Ohms on both + and Ground conductors.
So any over voltage protection and attenuation going on inside the black box on the lead isn't being done by reisstors
10 years 1 week ago #2237 by VizoEdward
Replied by VizoEdward on topic Secondary ignition waveform
Hello AM. The stated attenuation spec of the HT25 is 10K, according to enclose information sheet they provide with the tool. I believe that is accurate, as seen on your last two waveforms with 200 ms/dv or 2V per screen for a max of 20KV. Anyway, still that HT25 tool is not the one I refer in my case. Check on Hantek website for item HT25COP.
Let me ask you: I do not know the brand of scope you use, looking at the photos you send with the capture waveform it seem to be a Hantek. Now, does it change color on the trace on you when selected voltage scale is under the value of the actual captured signal. For example, in my case I selected a scale of 15KV per screen to view the secondary @ idle, but I can see the trace passing that point way up out of the screen. Is it possible that is the reason I am having this issue of change of color on my trace? Is this normal on any brand of scope or is it unique to Snap on products?. O worst yet indeed more voltage is coming in to the scope that it can handle?
By the way good trick on the capture o f the rover trace with your hand over the coil ! . Is it a 75 Land Rover?. It does recall some fun memories.
10 years 1 week ago - 10 years 1 week ago #2238 by Andy.MacFadyen
I really don't know about Snap-On scopes other than watching the vieos of Paul using them I have never had the pleasure of owning one.
My main scope is an Owon SDA7120v with the optional battery I like it because I like having real knobs and buttons It isn't perfect for automotive work but I find it quick and easy to use and I got it at a very good price. I have a Hanktek 1008 I keep is reserve in case I need more than two channels.
I was sitting waiting for the grand kids coming out of school and did some web browsing on protecting scope inputs and capacitive probes, interesting.
From what I can gather the output voltage of a capacitive probe is controlled by simply linking the ground and signal wires by a ressistor and capictor in parrallel.
The over voltage protection in the scope is also pretty simple just 4 diodes that act the same way as the zenner diode in a motorcycle voltage regulator and simply dump any excess voltage back to ground.
That captures were taken not from a Land-Rover but this car a now high mileage Rover 75 the last car model Rover made before they went bust 11 years later we still have a couple of them in the family fleet --- we used have a lot of various Rovers and MGs but the family are going Nissan and Renault :(
Last edit: 10 years 1 week ago by Andy.MacFadyen.
10 years 1 week ago #2239 by VizoEdward
Not to be sad and worry AM. at the very least you are expanding your frontiers with all those car manufactures in your hands. Add an American or German make to the list more international. Renault sure did not fair well with the American public. If my memory serve me well they have several F-1 championship under their belt. Nice.
My Snap On Vantage Pro bundle is 11.4 ( circa 2010) not even close to what Mr. Danner operate. Got it used, but still a treasure worth keeping it safe from misusage...........hope.
On any case, looks like my main concern with the usage of the HP25COP/Pico pp357) on this scope still inconclusive. Should I give it a green light to try the same capture on a different voltage scale?. Apparently that what Snap On thinks. I am tempted to do it but...............certainly will be nice to have the right answer?
Did you check the Hantek item HT25COP? Aside for what is happening to me it seem it is a better tool than the HT25.
10 years 1 week ago #2331 by rob.dotterer
Replied by rob.dotterer on topic Secondary ignition waveform
I am having this exact same issue with my Snapon Verus Edge and the Hantek HT25. My secondary ignition waveform looks like a really really tiny current ramp. I even bought a second HT25 thinking my first one was faulty with the same issue. I wish someone would find a solution for this.
10 years 1 week ago #2333 by VizoEdward
Eureka! I solved the issue of the changing color of the waveform on my Vantage with the HT25COP. It is indeed a relief. Both work pretty well together.
Now, Rob: First, a question: Are you using the Hantek HT25 (capacitive) wire with a clamp on one end, BNC connector at the other. Or are you using the Hantek HT25 COP ignition probe with the handle on one end, paddle( that you rest on the coil) at the other?. With both I am getting a trace I can certainly work. But the selection of the scope mode, scaling, trigger,etc must be change according to which of the two is used.
Example: A Secondary ignition waveform, COP system, at idle*.
With the HT25: Lab scope: Volts DC 400mv/div (2Vper screen); 10ms time; Channel 1 normal trigger@ rising slope with a 2ms delay, level 1.0V. Use the HT extension lead, Keep it away from other coils .
With the HT25COP: Ignition scope,single cylinder Ignition: Volts KV at 15KV; 20ms; channel 1, normal trigger @rising slope, 10ms delay, level 4KV. Important: Install a 20:1 attenuator! , rest the probe paddle square on top of the selected coil.
*To test at higher RPM adjust accordingly.
10 years 1 week ago #2345 by Noah
Replied by Noah on topic Secondary ignition waveform
Andy.MacFadyen wrote: The method used to do the capture was to use a basic crocodile clip lead. Scope ground connected to a block ground, scope positive is gripped in one hand while the palm of the other hand is simply held about 2 to 6 inches above the coil.
I have since tried it with DSO201 Nano and it also works nicely with that. ;)
That's absolutely wild! I'm admittedly novice when it comes to secondary waveforms, but I have never seen or heard of anyone capturing a waveform with that method.
10 years 1 week ago - 10 years 1 week ago #2346 by Andy.MacFadyen
I suspect it won't work on some plug top coils, these captures were taken from a plug top coil with a wasted spark for the companion cylinder.
Interestingly the alternator ripple is alao being picked up--- that is really crazy.
I have seen a short video on YouTube of another method that I will try out next time I get a suitable vehicle in.
link to video
8 years 11 months ago - 8 years 11 months ago #13914 by SailorBob
Replied by SailorBob on topic Secondary ignition waveform
I'm having fun with my Hantek 1008C and tried it out on my ignition system today using the HT25 inductive clamp probe. My 98 Mazda 626 GF 2L uses a coil pack waste spark system with each coil firing two plugs simultaneously. I'm pretty new to scopes. Like really new.
I took a short one minute video and captured a few individual wave forms. Going over that video in slow motion I saw quite a variety of waveform shapes, however the fire lines were all about 2 milliseconds which is supposedly pretty good and close to the maximum possible. I don't think the scope was displaying every single spark event because I had the trigger set fairly high, however these two basic waveforms were the most common:
This seems pretty normal, but I was wondering why that second spike was so high? Just allot of energy to wring out?
This is the other common one, and I'm assuming this is the waste spark?
My odd numbered cylinders where upside down like this. I wanted to do the 10k X scaling for this probe, but couldn't get it to work, so I just left it in mV.
I mentioned that I saw a variety of waveforms on slow-mo in the linked video; how much do I care about the exact shape especially of regarding the shape of the burn line?
Last edit: 8 years 11 months ago by SailorBob.
8 years 11 months ago #13915 by Andy.MacFadyen
A waste spark system is exactly that on any single cylinder every 2nd spark is wasted there isn't any point looking at wasted sparks. On a the the wasted sparks peak voltage is lower peak voltage and the spark line voltage is lower. As a result at the end of the spark energy is left over this causes the rising voltage forming the toe at the end of the spark.
When looking at ignition secondary traces on wasted spark systems the trigger level should be set high enough to trigger only ignition firing sparks not wasted sparks.
If you find a significant "toe" voltage at the end of an actually firing spark then it could point to a plug lead or plug shorted to ground or a spark plug gap set too narrow.
With a wasted spark system the companion cylinder can also affect the spark line on the cylinder you are looking at.
8 years 11 months ago #13929 by SailorBob
OK, so I was reading this article from Motor magazine and those are apparently both normal sparks, and in a waste spark system, the waste spark is superimposed on the firing spark and can be seen as the thick spot on the firing line:
8 years 11 months ago - 8 years 11 months ago #13930 by SailorBob
I think I just realized that scopes translate time as well? When I was looking at the spark with my divs set to 2ms I could actively see the shape of the spark changing and updating. When I set it to 20ms I could still see the shape of the spark changing on the screen, but more slowly, and when I set it to 100ms I could only see static pictures, sometimes the screen would only update once every few seconds. That makes me wonder if maybe I messed something up in the settings or have a defective probe or scope.
I also saw some things I quite frankly didn't understand. When I set it to 20ms/2kv with a 5kv trigger I saw these shapes on both sides of the spark:
Then when I set it to 100ms/2kv with a 2kv trigger things got stranger:
What am I seeing? Is there something wrong with my scope or setup? I was using an HT25 inductive clamp probe attached to the plug wire and grounded to the engine.
Maybe I was picking up noise from other things because I grounded the probe to the engine ground and not the battery?
The engine was running about 750rpm here which translates to 6.25 hertz, which would give me a spark on that plug once every 1.5 seconds approximately.
8 years 11 months ago #13932 by Andy.MacFadyen
The Hantek 1008 is a very limited scope if you expand the time per division the detail not only only disappears but it can totally destroy the detail and create "scope artifacts".
On a waste spark system with the Hantek you will only really to be one spark in useful detail.
The article and illustrations in Motor magazine are showing what you would see on a old style cathode ray oscilloscope, with a cathode ray tube the glow of the phosphor coating has persistence ie it continues to glow after the trace has moved on, you won't see the two traces superimposed on Hantek.
Also on modern ignition system because coils are smaller and spark plug gaps are wider there is less energy trapped in the coil when the spark dies out so the coil oscillations tend to be smaller so don't expect to see large oscillations as in the graphics.
The real guru of ignition scope work is a guy called Jim Morton he has some video on YouTube --- serious stuff worth watching
8 years 11 months ago #14034 by SailorBob
I just ran across a really nice, very technical discussion of ignition coil design and operation from a company named Beru that manufactures them: All about ignition coils
8 years 11 months ago #14082 by juergen.scholl
Replied by juergen.scholl on topic Secondary ignition waveform
Andy,
sure that Jim Morton is a true master not only of ignition scoping but on automotive diagnostics in many regards; as well as Bill Fulton is. From the latter is the famous "10 minutes secondary quick check" approach, which can be found within the TST videos too, or AVI.
The true ignition guru to me is the former ALLEN engineer Mac Vandenbrink. His alltime favorite is called "exploring combustion behaviour through the eyes of a scope" and this is just about what the title indicates.
You still may find this thru AES wave in DVD form and you may really enjoy to "discover the hidden secrets of scope pattern interpretation, if you do not know it already.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
8 years 11 months ago #14177 by Dylan
Replied by Dylan on topic Secondary ignition waveform
I agree Juergen ;)
Here's a video from TST seminars with Mac Vandenbrink:
8 years 11 months ago #14372 by SailorBob
Ran across this great article by Mac Vandenbrink on scoping DIS waste spark ignitions: www.searchautoparts.com/motorage/training/science-scopes
8 years 7 months ago #18428 by Minetsky
Replied by Minetsky on topic Secondary ignition waveform
Hi sir. Have you tried the ht25cop at snap throttle? Hows the waveform? I dont see a ground wire on the probe how is the design of that probe? Thanks
6 years 2 months ago - 6 years 2 months ago #41835 by al514
Replied by al514 on topic Secondary ignition waveform
You definitely need a x20 with the ht25cop? Why wouldn't they have it built in, the ht25 seems to be fine with built in components. and technically can't ya just clamp a penny onto the ht25 and put it over the coil and it should work? I think.
Last edit: 6 years 2 months ago by al514. Reason: Added
6 years 2 months ago #41840 by Andy.MacFadyen
al514 wrote: You definitely need a x20 with the ht25cop? Why wouldn't they have it built in, the ht25 seems to be fine with built in components. and technically can't ya just clamp a penny onto the ht25 and put it over the coil and it should work? I think.
HT25 is the the ignition secondary probe for measuring KV so it acts as a 10,000 : 1 attenuator and would reduce a typical 40KV to 4 Volts.
A 20:1 attenuator is for ignition primary (also often used for injectors) because coils are inductors that produce "back EMF" spikes when the coil is switched off of 80v or so.
Time to create page: 0.396 seconds
