Corolla VSC
  • karim
  • karim's Avatar Topic Author
9 years 2 months ago #12605 by karim
Corolla VSC was created by karim
Dears,
My brother has a Toyota Corolla 2016 European version. KOEO, does not show VSC available but when I use techstream to check instrument cluster component light, I can turn VSC light on and off as a source to test the vsc.
Does this car has vsc or not? How can I know if it has vsc or not? using scanner or other methods?
Thank you
9 years 2 months ago #12607 by matt.white
Replied by matt.white on topic Re:Corolla VSC
Has it got a button like this? I would suspect you're simply communicating with the instruments, regardless of whether the car has that feature or not.
  • karim
9 years 2 months ago #12608 by karim
Replied by karim on topic Re:Corolla VSC
No, it doesnt have that switch.
9 years 2 months ago #12609 by Gjauto
Replied by Gjauto on topic Re:Corolla VSC
Jack up the drive wheels and put vehicle in drive. See if wheel spin is limited and light on cluster flashes.
The following user(s) said Thank You: karim
9 years 2 months ago #12612 by matt.white
Yeah or do what gjauto suggested. All Toyotas as far as I'm aware and have owned have a vsc off button when it's fitted. Refer to the owners manual for vsc and it should give a hint as to whether it's fitted or not.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 2 months ago #12630 by Dylan
Replied by Dylan on topic Re:Corolla VSC
matt.white wrote: Yeah or do what gjauto suggested. All Toyotas as far as I'm aware and have owned have a vsc off button when it's fitted. Refer to the owners manual for vsc and it should give a hint as to whether it's fitted or not.
If it has VSC, just like Matt said I think there should be a switch. You can do what Gjauto says or just go for a testdrive.... :whistle: ;)
9 years 2 months ago #12633 by Gjauto
lol go do some burnouts man. shouldnt be too hard.. wait.. corolla.. european edition... whats that like a .5L engine? Might want to put some water or gravel down.
9 years 2 months ago #12667 by matt.white
Hahahaha I love toyotas but thanks for the morning laugh.
