Carboned intake valves and intake pulses
- matt.white
- Thank you received: 29
My question to the forum is, assuming the misfire comes from leaking valve seats, is it possible to see any form of uneven pulses in the intake? I scoped the MAP but it was completely flatline. I've read people talk about first look sensors but have no experience at all with them. Is this what I should be looking at? Any input genuinely appreciated.
Andy MacFadyen has posted about more affordable versions of the FirstLook, and I've been very tempted to get one. The name brand sensor goes for around $400 last time I looked, a bit too steep for me.
I've also had luck scoping the MAP sensor, using AC coupling. I usually use it to find valve adjustment issues on Honda's, but the same principle applies. The only problem is the location of the MAP sensor on the intake, as it needs to be as centrally located as possible.
I'd like to see this process if you maybe felt like starting a thread... :whistle:I've also had luck scoping the MAP sensor, using AC coupling. I usually use it to find valve adjustment issues on Honda's, but the same principle applies
Simulating the leaking intake valve will be tough, maybe we'd have to settle for a loosened spark plug?
- matt.white
I didn't even think about ac coupling. This job was one of those ones where you know what's wrong and you're expected to just fix it. I thought I'd just quickly throw the scope on it and see what it looks like before I rip into it.
One reason in particular I'm questioning the process is the same cars we're starting to see injectors failing mechanically to the point of jamming open and flooding the car. In the back of my mind I'm thinking it'll get to the point one day where I do a carbon clean and miss a failing injector. I need to get my head around some sort of routine or procedure to diagnose gdi systems. Maybe it's just me. I'm pretty confident diagnosing blocked port injection injectors but still pretty green on gdi.
The more I learn off guys like you two and Paul the more I realise i don't know. Lol
40 years back the bitter sweet pleasure of owning and occaisionally racing a Lotus with the old Lotus-Ford Twincam engine and because of this I looked afer a couple more. Outside of the USA these engines had twin Weber 40DCOE carbs so like a motorcycle each cylinder had one barrel directly feeding each cylinder with no plenum or balance tube. In those days we used to synchronise the the carb butterflys by ear using a sethoscope held at a sweet spot in the carbeurettor trumpets.
It was really easy to bend a valve on these engines but listening to the inlets a inlet valve that wasn't sealing would make a very distinctive plop-plop sound.
- matt.white
I love old war stories.
Noah wrote: You don't have to go nuts, I figured you had some captures saved in "Tyler's Super Library Of Awesome Waveforms and Data PID Captures"
Haha no intake stuff, sorry, mostly because I've started using the in-cylinder transducer more often.
Matt, yeah the plug wouldn't be a great simulation, but I think it would produce some kind of change in the intake? Because that cylinder is no longer producing the same amount of vacuum? Maybe I'm thinking of it wrong.
Talking about procedural stuff, did your Commodore come with an injector balance scan tool test? The newer GM GDI engines (including the High Feature engines, as we know them) I've seen all come with an automated balance test, which I've been playing with when I can. I can post some scan data captures of a test if you want.
- matt.white
Yes true with the lower vacuum created with a loose plug. Totally missed that. I was thinking more of any positive pulses back into the intake through the leaking valves.
Totally up to you man. Do you run SO gear? You know if it's in functional tests?
With the AC coupling, that removes the DC part of the signal doesn't it? So then you can really focus on the slight variations in the signal? Sorry for the noob question.
