Hantek 1008C 350 Spark problems?
  • jdkoontz
  • jdkoontz's Avatar Topic Author
2 years 3 weeks ago #67178 by jdkoontz
Hantek 1008C 350 Spark problems? was created by jdkoontz
I have a 350 Chevy running rough.
The dist is a small cap Summit Racing Electronic ignition. Coil is a 8222.
Have I got this setup right? The spark signal looks noisy?
Is this a bad coil? Or bad ignition module?
2 years 3 weeks ago #67179 by juergen.scholl
Replied by juergen.scholl on topic Hantek 1008C 350 Spark problems?
Where exactly are you connected to with your leads?
I am afraid this scope is not capable of delivering useful captures on that long a timebase on high frequency signals as ingnition events are
  • jdkoontz
2 years 3 weeks ago #67180 by jdkoontz
Replied by jdkoontz on topic Hantek 1008C 350 Spark problems?
Channel1 is on #1 spark plug wire. Channel2 is on coil wire. Both are inductive probes.
2 years 3 weeks ago #67183 by juergen.scholl
Not doubting your words but I suspect you're actually using capacitive probes. This scope's limitation regarding sample rate combined with the applied time base/settings makes it next to impossible to capture meaningful secondary waveforms imo.
A1 is just an example waveform overlayed on the screen?
  • jdkoontz
2 years 3 weeks ago #67184 by jdkoontz
The probes are HT25 hantek. They are listed as inductive capacitive? Does that make sense?
  • jdkoontz
2 years 3 weeks ago #67185 by jdkoontz
A1 is the example from hantek.
  • jdkoontz
2 years 3 weeks ago #67186 by jdkoontz
I'll rescan today to supply better scan.
  • jdkoontz
2 years 3 weeks ago #67187 by jdkoontz
Did another scan this afternoon.
  • jdkoontz
2 years 3 weeks ago #67188 by jdkoontz
Channel#3 is coil wire. Channel#1 is cyl #1.
  • jdkoontz
2 years 3 weeks ago #67189 by jdkoontz
Why does the coil scan get inverted? Seems like the #1 cyl is not inverted?
  • jdkoontz
2 years 3 weeks ago #67192 by jdkoontz
Had a spare coil, so I swapped it out to see if the coil was the problem.
Coil now looks good, but can someone tell me why the coil signal is inverted? Is that OK for these scopes?
  • jdkoontz
2 years 3 weeks ago #67193 by jdkoontz
Channel3 is the coil wire. Channel5 is plug #1 wire. Does this plug signal look correct for this scope?
2 years 3 weeks ago #67196 by juergen.scholl
What you describe as an "inverted" signal of the secondary ignition is completely normal on negative fired ignition systems. The voltage is seen as "outgoing"
Dedicated ignition scopes directly invert the view so you'll see an upside image. If your scope doesn't do this automatically you still can manually invert the image to see in the 'typical' way if you prefer so.
The following user(s) said Thank You: jdkoontz
  • jdkoontz
2 years 3 weeks ago #67204 by jdkoontz
Found the invert settings.
Is this a normal view of the plug wire probe when that cyl is firing?
Is the slow voltage decline telling me anything?
Time to create page: 0.394 seconds
