Best piercing probe?
- RCB
- Heavy-duty diesel mechanic based in Oregon
2 years 1 month ago #66881
by RCB
As a heavy-duty diesel mechanic based in Oregon, I work on a variety of vehicles, including F-150s, tractor-trailers, RVs, pumper trailers, wood chippers, and whatever else the owner brings in.
Best piercing probe? was created by RCB
I've been trying to get a Phil's Piercing Probe, but it's always out of stock on ASC Wave. Who makes the best piercing electrical probe that are available to purchase
2 years 1 month ago #66883
Replied by Noah on topic Best piercing probe?
The best ones I have used as far as: 1) always hitting the wire,
2) not breaking after 5 uses,
3) ease of application are the Power Probe yellow and green piercing probes. The only draw back is they use a male banana plug so you need an adapter or female lead to connect them to most meter leads.
The long AES wave ones suck. The thumb screw is reverse thread, the needle always misses the conductor in the wire and they break easily.
The following user(s) said Thank You: tmcquinn, 00Jake00
2 years 1 month ago #66899
Replied by Tyler on topic Best piercing probe?
The best ones are, unfortunately, the Phil's probes. I grabbed three of the short ones the last time they were available.
If not the Phil's, then I'd vote for the Pomona probes:
www.aeswave.com/Adjustable-Insulation-Pi...ug-Inputs-p8507.html
They're compact, consistent-ish about actually piercing the wire, durable and not so expensive that you cry if you lose one.
- 00Jake00
- Thank you received: 7
2 years 1 month ago #66902
by 00Jake00
Replied by 00Jake00 on topic Best piercing probe?
I've been trying to get some Phil's probes but like ya say they're always out of stock. I like using the bed of nails alligator clamps when I can but if there's no room then I use the yellow and green power probe ones. Yes you have to get special leads for them so you can use them with most meters and scopes. Power probe sells a lead set and the leads are like 6ft long which is nice. I've been eyeing up those little yellow ones, I see JDTCO has their own at a pretty good price.
2 years 1 month ago #66905
I saw that! Not sure if that's an in-house knock off or what.
I've only used the genuine Pomona ones before, so I honestly know how well those'll work. If you get some, let us know how they hold up.
1 year 11 months ago #67532
Heads up, two of the Phil's probes are back in stock on AESWave.
www.aeswave.com/Phil-s-Short-Electrical-...-7-8-inch-p9904.html
www.aeswave.com/11-inch-Phil-s-Electrica...ing-Probe-p8557.html
