Hantek Coil-on-Plug extension leads(HT308)
- scopeman
- Thank you received: 3
9 years 3 months ago - 9 years 3 months ago #11373
by scopeman
Hantek Coil-on-Plug extension leads(HT308) was created by scopeman
No eBay APP ID and/or Cert ID defined in Kunena configurationAre these leads any good for getting secondary wave forms and are they needed to get a better diagnosis on systems like multi coil packs that are all one unit ?
Was thinking of getting some to test on my coil pack unit that fits directly on the spark plugs .
Last edit: 9 years 3 months ago by scopeman.
9 years 3 months ago - 9 years 3 months ago #11381
Replied by Andy.MacFadyen on topic Hantek Coil-on-Plug extension leads(HT308)
Those 4 cylinder cassette modules are pita, It will work I have used a single lead to check a two cylinder plug top coil, the main problem is keeping the coil from bouncing around when the engine is running. I have alligator clips on the ground lead to make grounding the coil easier.
Paul has a good video on these coil cassettes on his premium channel 2004 Saturn L300 No Start, No Spark case study
Last edit: 9 years 3 months ago by Andy.MacFadyen.
The following user(s) said Thank You: scopeman
9 years 3 months ago - 9 years 3 months ago #11389
- scopeman
9 years 3 months ago - 9 years 3 months ago #11403
by scopeman
Replied by scopeman on topic Hantek Coil-on-Plug extension leads(HT308)
Hi Andy, thanks for the reply..Was not sure if i should have got them as i was looking at the pico website that sells similar leads ( price is double for a set of 4 on there ) .Have watched Paul's vid as i subscribe to his premium channel ,thanks for the link.Would the secondary waveform (which seems to be only got using these leads if i am not mistaken ,please correct me if i am wrong ) be more useful than current ramping ?
