Best back props
  • Amich28
  • Amich28's Avatar Topic Author
9 years 3 months ago #10853 by Amich28
Best back props was created by Amich28
Best place to buy a good back prob kit. I have ford front flex props but need some back probs. Got some from a truck and voltage jumps around do to the bad connection inside the back probs.
9 years 3 months ago #10857 by Tyler
Replied by Tyler on topic Best back props
The AESWave uMicroBackProbe has become by go-to since I got them a few months ago:
www.aeswave.com/uMicroBackProbe-Minimum-...onnectors-p9481.html
I'm also a big fan of the Accupuncture set. Costs more, but you get multiple sizes of pin for different applications. Worth it, IMO.
www.aeswave.com/AES-Electronics-Accupuncture-Probes-p9474.html
I've also tried the Hantek backprobe set, which is very reasonably priced.
www.amazon.com/Hantek-Pinning-Probes-Pie...sorted/dp/B008L1JT34
The problem with these is how the pin tends to come loose, and the lock screw can't be tightened down sufficiently to fix it. Makes the probe feel flimsy. :(
  • Amich28
9 years 3 months ago #10863 by Amich28
Replied by Amich28 on topic Best back props
Thank you so much. I'm going to be looking to get the aeswave set. No since in buying a cheap set and then fail a component. Got a set on the matco truck and don't like them
9 years 3 months ago #10911 by Noah
Replied by Noah on topic Best back props
I've got the micro probe set from aes wave, I think those are probably my favorite.
I've also got a box of them with jumper wires from a tool truck at the shop that are pretty good for like $25.
I don't mind so much when I mangle one of those or drop it under the intake somewhere, never to be seen again...
Time to create page: 0.339 seconds
