Pull-Down Hall Effect Sensor
- ksat22
- Thank you received: 9
2 years 11 months ago #63768
by ksat22
Pull-Down Hall Effect Sensor was created by ksat22
When this type of sensor is not in it's pulled-down state (i.e. not triggered), is the 5V that is found on the signal wire sourced from the sensor's 5V voltage supply wire?
- Paul P.
- Thank you received: 195
2 years 10 months ago #63778
by Paul P.
Never stop Learning.
Replied by Paul P. on topic Pull-Down Hall Effect Sensor
It is sourced from the PCM. The Sensor will Pull-Down this voltage when it is triggered.
Quick check, Key ON, sensor unplugged, there should be 5 volts present on the signal, or there is a problem, open, short, pin fitment or PCM.
A pull-up sensor is sourced from the 5v ref, so when this sensor is triggered it pulls the signal wire up to the reference voltage.
I hope this helps.
I hope this helps.
- ksat22
2 years 10 months ago #63781
by ksat22
Replied by ksat22 on topic Pull-Down Hall Effect Sensor
Thank you and, yes, the explanation helps a lot!
I was watching several YT repair vids where sensor bypass tests were being performed- that is, ground was applied via a jumper to the sensor signal wire- and I wasn't sure if the sensor needed to be plugged in so it could provide the steady 5V or if the voltage was sourced from somewhere else.
Just 1 more question, if you don't mind: With a pull-up sensor setup, instead of supplying 5V like in the pull-down design, does the PCM apply ground to the signal wire instead?
- Paul P.
2 years 10 months ago #63786
by Paul P.
This is why it is very important to do the "unplug-it" test to verify the voltage level on the signal wire.
Signup for SD Premium, Paul Danner has an awesome 4 or 5 part series on Signal Circuit integrity. This is a MUST watch.
This "by-passing" is done on three wire sensors ( ie. Crank or CAM Position) to set either Circuit High/or Low codes. This is often done to prove circuit integrity and that the PCM is doing its job and the said part is bad. By-pass testing is performed (usually) with the circuit unplugged to isolate the sensor. Depending on sensor design, Pull-up, or Pull-Down you can ground the signal and pull it down like a pull-down sensor would OR jump the 5v reference the signal to pull-up the signal like a pull-up sensor would do.that is, ground was applied via a jumper to the sensor signal wire- and I wasn't sure if the sensor needed to be plugged in
The PCM continually supplies a ground to a three wire sensor, the sensor when triggered pulls-up the voltage on the signal or it allows the 5 volt reference voltage a path to the signal wire. With this sensor design there will be "Zero" volts on the signal unplugged.With a pull-up sensor setup, instead of supplying 5V like in the pull-down design, does the PCM apply ground to the signal wire instead?
