What this means? Using Verus Edge 22.0
  • Mechanic 350
  • Mechanic 350's Avatar Topic Author
3 years 2 days ago - 3 years 2 days ago #63400 by Mechanic 350
What this means? Using Verus Edge 22.0 was created by Mechanic 350
AF FB (short term)
AF FB AVE (long term)
i know short and long term, but not the other abbreviations
Plus, I can't find B1S1 voltage PID on the scanner under emmisions tab.  any help?
having steady negative fuel trims all the time.
Last edit: 3 years 2 days ago by Mechanic 350.
3 years 2 days ago #63406 by Noah
Replied by Noah on topic What this means? Using Verus Edge 22.0
Honda?
I think it's Air Fuel Feedback and Air Fuel Feedback Average.
If I see something I don't quite understand as far as trims and oxygen sensor voltages, I'll check generic OBD2 data. It kind of the equalizer.
There probably isn't one called "b1s1" because the upstream is likely a wideband sensor. The data is probably displayed in mA, not bolts like we've gotten used to.
The following user(s) said Thank You: juergen.scholl, Chad
  • Mechanic 350
3 years 2 days ago #63407 by Mechanic 350
Replied by Mechanic 350 on topic What this means? Using Verus Edge 22.0
ok, thank you Noah.
