Re:Wiring Diagrams 2010 Scion XB
- Stryper
3 years 3 months ago #62456
by Stryper
Wiring Diagrams 2010 Scion XB was created by Stryper
Whats the best place to access a single vehicle wiring diagram? 2010 Scion XB Fuel Pump circuit actually.
TIA,
Michael
TIA,
Michael
- Ben
- Thank you received: 215
3 years 3 months ago #62457
by Ben
Replied by Ben on topic Re:Wiring Diagrams 2010 Scion XB
- Stryper
3 years 3 months ago #62458
by Stryper
Replied by Stryper on topic Re:Wiring Diagrams 2010 Scion XB
Thank You Very Much! Just Double checking everything. That plastic ring that holds the assembly in place is the most cussworthy item
Regards,
Michael
Regards,
Michael
- Ben
3 years 3 months ago #62459
by Ben
Replied by Ben on topic Re:Re:Wiring Diagrams 2010 Scion XB
If you dont have the tool Autozone rents it #25156
- Stryper
3 years 2 months ago #62540
by Stryper
Thanks Ben for the offer
turns out I do need another section. Same XB now has a P0717 and its only getting 0.80-0.86v with key on and with engine running. So power has to come from somewhere ! And I have no idea how to word it, transmission wiring diagram?
TIA,
Michael
TIA,
Michael
- Ben
3 years 2 months ago #62541
by Ben
- pinstryper
3 years 2 months ago #62542
by pinstryper
Replied by pinstryper on topic Re:Re:Wiring Diagrams 2010 Scion XB
No labscope, but sensor was swaped and got worse. Re installed original and went from intermittant to full time issues. So bias voltage has to come from somewhere and it appears to come from ecu? No relay ? FK! , i just got fuel issues sorted and mtr mts and its been running great.
- pinstryper
3 years 2 months ago #62543
by pinstryper
Found out sensor ohm is 540-680 so 600+/- 10% will check continuity when we dip into the 90°s
- daisy887a
3 years 1 month ago #62845
by daisy887a
Replied by daisy887a on topic Re:Re:Wiring Diagrams 2010 Scion XB
