Re:Exhaust Restriction
- Stryper
3 years 3 months ago #62250
by Stryper
Exhaust Restriction was created by Stryper
I tried doing it at the sensor 1 location (easiest) but only had a regular compression tester to use. And it was analog not digital. Did not even bump the needle. I'm guessing a regular compression gauge is just not sensitive enough?
Anyone have any luck with the vacuum test ? as far as exhaust restriction ?
Just waiting for my book to arrive, so I can follow along and take concise notes
3 years 3 months ago #62252
Replied by Noah on topic Exhaust Restriction
I like to use a vacuum/pressure gauge in the exhaust to test for restrictions. As you noted, the compression gauge is not sensitive enough.
www.harborfreight.com/fuel-pump-and-vacuum-tester-62637.html
I do not measure engine vacuum to check for a restricted exhaust. Pressure measured in the exhaust is much easier to spot in my opinion.
An in cylinder pressure transducer does a great job showing restricted exhaust also, but it takes some training, and obviously a transducer, to interpret the results of that test.
- pinstryper
3 years 3 months ago #62254
by pinstryper
Replied by pinstryper on topic Re:Exhaust Restriction
So where did you find an adapter to fit into the O2 sensor bung? I actually needed a new vacum gauge anyway
But now trying to figure out something to adapt it ?
Thanks,
Michael
Sent from my SM-G991U1 using Tapatalk
Thanks,
Michael
- pinstryper
3 years 3 months ago #62256
by pinstryper
3 years 3 months ago - 3 years 3 months ago #62261
Replied by Noah on topic Re:Exhaust Restriction
Last edit: 3 years 3 months ago by Noah.
- pinstryper
3 years 3 months ago #62306
by pinstryper
Thats great if you can reseal it, i guess on a personal vehicle you could use a sheet metal screw. I was lucky enough my upstream 02 was easy to get to, and BIGTHANKS to fellow for heads up to HF tester!
And i managed to cobble an adapter and now have another arrow in the quiver! for 16$ yippie!
