Low amp clamp
  • Failed Test
  • Failed Test's Avatar Topic Author
3 years 6 months ago #61008 by Failed Test
Low amp clamp was created by Failed Test
Hello everyone, I am new to using scopes and not to rich so for now I use the Pico 2205A 2nd to the lowest pico you can get. Watching tons of youtube videos shows me the value in doing relative compression testing. I also have the Pico Ta234 low amp clamp. Can this be used for RC tests? I can't seem to get the scope settings right. I got the low amp one thinking I could just scale it up and save money and it has a nice size jaw to easily clamp around battery cables. A setting screen shot or video link with a demonstration? or no dummy it wont work :lol:
Thanks
3 years 6 months ago #61010 by Ben
Replied by Ben on topic Re:Low amp clamp
Yes it can. set your scope to 2v dc and time base around 1 sec/div
The following user(s) said Thank You: Failed Test
3 years 6 months ago #61011 by juergen.scholl
Replied by juergen.scholl on topic Low amp clamp
The Ta 234's usable range is 5 to 30A as per spec. Though typically current clamps measure well beyond their nominal spec you may encounter limitations (clip off) on diesel and big gasoline engines when DC-coupled. In this case use the AC-mode.
3 years 6 months ago #61012 by Ben
While your at it you should try hooking a 2nd channel directly to the battery with AC couple and compare it to the amp clamp (you will have to invert it in the software)( I don't recommend reversing polarity on non floating ground scopes.)
3 years 6 months ago - 3 years 6 months ago #61013 by juergen.scholl
Replied by juergen.scholl on topic Re:Low amp clamp
Especially on a common ground scope when using more than one channel!
Another great way for RC is voltage drop measurement from block ground to negative battery post.
Last edit: 3 years 6 months ago by juergen.scholl.
Time to create page: 0.266 seconds
