Re:Scoping ground control wire on ignition coil
  • ksat22
  • ksat22's Avatar Topic Author
3 years 7 months ago #60794 by ksat22
Kind of a noob question here, but I wanted to use my scope to test for the ground control signal (originating from PCM) at the ignition coil connector, with it unplugged and I'm a little unsure how to connect my leads up. If probe positive goes on the ground control wire and probe negative goes on battery ground will my scope show anything as, I imagine, there won't be any potential between the 2 leads?
3 years 7 months ago #60795 by Ben
Good question I have not tried with coil disconnected as I haven't felt like I needed to just see an unloaded command but I don't see why it wouldn't work as long as you have a floating ground scope or are only using 1 channel of a shared ground scope. Typically we leave the coil connected and attach ground lead to ground and positive lead to ground side of ignition coil than you can see the grounding command and the primary ignition signal.
3 years 7 months ago #60798 by juergen.scholl
Replied by juergen.scholl on topic Re:Scoping ground control wire on ignition coil
All what Ben said.plus:
With the suggested hook up while not pulling the coil control wire (#1) to ground you'll be dealing with an open circuit and measuring "ghost voltage" that turns into a direct short once pulled to ground, showing 0V.
From a diagnostic standpoint that way you're not loading the circuit adequately and may miss high resistance issues on the control wire.
Hooking up a test light to B+ and the control wire or installing a noid light in place of the coil will allow for checking coil control quickly. The test light check will work even with the coil in place.
Some pcm may cancel coil activation when seeing an open circuit with the coil disconnected.
3 years 7 months ago #60820 by Noah
That is certainly something to be aware of. I had a Chrysler product the other day that would only do so for cylinder #1
  • ksat22
3 years 6 months ago #60854 by ksat22
Thanks for the replies. I was watching a DiagnoseDan vid on the youtube and at one point he got a trace of the PCM signal and just was curious how he did that. He was working on a Beemer, so maybe it used a +12V signal instead of ground control?
I'll post a link to the vid below, if anyone's curious to see it. Scroll to ~20:25 mark.
3 years 6 months ago #60855 by juergen.scholl
This happens to be a different animal.....
The signal shown in the video is actually a control signal which the pcm sends out to the power transistor which controls the specific coil. The scope in this case is NOT connected to the negative side of coil primary, only to coil control. This is a regular square wave and there is no inductive kick as you would see when connected to coil negative as around 7.00 of the same video.
It's easy to see this kind of control signals on 3 and 4 wire coils. They internally feature an ignition control module which is told by the pcm when to switch on and off primary current. This order is sent from the pcm to the coil's integrated ICM as a discrete voltage signal and you would connect the signal probe of one scope channel to this control wire and the ground lead to chasis ground or bat negative.HTH.
  • ksat22
3 years 6 months ago - 3 years 6 months ago #60870 by ksat22
Okay, thanks very much for clearing that up. Probably should have watched it a few more times before posting... Just so I'm clear, this system is using it +5 or so volts to activate the transistor there, is that right?
Last edit: 3 years 6 months ago by ksat22.
3 years 6 months ago - 3 years 6 months ago #60871 by juergen.scholl
Okay, so he's measuring inside the PCM itself on the control side (gate) of the transistor
Yes.
which would most likely be +5V coming from the CPU (as he calls it)?
It could be any voltage depending on the transistor.....
Coils with integrated module I often see getting control signals of around
3.5 to 4.5 volts.
Last edit: 3 years 6 months ago by juergen.scholl.
The following user(s) said Thank You: Noah, ksat22
  • ksat22
3 years 6 months ago #60872 by ksat22
I enlarged the trace he got in the vid and it looks to be a little less than +5V. \
Thanks again!
