Secondary Ignition patterns on the MT2400 Scanner? KV module?
- markhthompson7
3 years 10 months ago #59410
by markhthompson7
Secondary Ignition patterns on the MT2400 Scanner? KV module? was created by markhthompson7
I have just purchased a Snap on version 6 MT2400. It didn't come with the KV module set, but I can purchase one if needed.
I would like to know if I will be able to view the secondary ignition pattern for at least one cylinder on the MT2400.
I'm hoping someone can give me some insight on this.
Also, maybe someone has a KV module manual in PDF.
Thanks much in advance
Mark
Mark
3 years 10 months ago #59424
Replied by Noah on topic Secondary Ignition patterns on the MT2400 Scanner? KV module?
Mark, while the MT2400 is my go to meter, there are far better options to view secondary ignition patterns.
With the kV module and the Vantage, you are limited to viewing only portions of the pattern at a time.
It can display the high kV firing voltage, or the burn line/duration, but not both at the same time.
I had the kV module and found it quite useless, I gave it to a member iatn a few years back.
For the money and leg work it will take to procure this antique, you could get one of those nice little pocket u-scopes everyone seems to be using and be WAY ahead of the Vantage in terms of ability to view secondary (and most other) waveforms.
I use my Vantage every day, in my eyes, it's the perfect multi meter, but when I need to SCOPE something, it goes back in the tool box.
- juergen.scholl
- Active partschanger
- Thank you received: 462
3 years 10 months ago #59426
by juergen.scholl
Replied by juergen.scholl on topic Secondary Ignition patterns on the MT2400 Scanner? KV module?
Mark,
You will not be able to "see" the 2ary ignition pattern in the way a regular ignition scope would show it.
Instead the MT 2400 will display a histogram of one aspect of the 2ary ignition like spark kv, firing kv etc. at a time. The graph will show how the selected aspect behaves over time and allows to spot easily deviations and abnormal events.
To get a better idea how it works and what it does you may have a look at the video:
Sure, in a world of "easy to digest approaches" there are less cumbersome options than this in particular. Nevertheless I think it is a great choice for advanced diying. Used modules used to be dirt cheap because they often were misunderstood. In a professional shop environment you'd prefer something different, imo.
- markhthompson7
3 years 10 months ago #59427
by markhthompson7
Replied by markhthompson7 on topic Secondary Ignition patterns on the MT2400 Scanner? KV module?
Noah,
Thanks much for your help on this.
I will save the money on the KV module and use the MT2400 a graphing multi meter.
Thanks again
Mark
Thanks again
Mark
- markhthompson7
3 years 10 months ago #59428
by markhthompson7
Juergen,
Thanks much for responding and providing great insight on this.
I have viewed the video.
I have other scopes but these are not so portable.
I got the MT2400, because I watched Paul use it so much in the videos.
I use a Fluke 77 multi meter, but it's not a graphing meter. I purchased it in 1983, while attending my first automotive electronics class at a GM training center. It's still working!
I'm putting together a road kit, since most of my work in helping friends away from my shop. Now it's boats as well.
I just purchased a Vantage Ultra with the latest software 22.4. Combined with my other equipment including the MT2400 my road kit is close to being together.
Thanks so much,
Mark
Thanks so much,
Mark
- Baymaster
3 years 7 months ago #60386
by Baymaster
Replied by Baymaster on topic Secondary Ignition patterns on the MT2400 Scanner? KV module?
I used the original vantage meter with kv module for years professionally. It is terrific for scoping ignition. I used it mostly with the ford cop adapter and helped my diagnostic process immensely. That being said, I used bear machines and the snapon counselor scope before I purchased the vantage.
I don't particularly use it for ignition anymore because I work on newer cars and do much less diagnostic. But I had a pretty big advantage over most techs probably 15 years ago with it. I have the vantage pro now and can't even remember if it has kv module built in.
Are there better scopes out there? Sure. Do any have more diagnostic info on hand than snapon? Probably not. The only thing I didn't use or trust on the vantage was the ohm meter because it cannot measure extremely high resistance.
Time to create page: 0.325 seconds
