Test Leads
  • manelishi
  • manelishi's Avatar Topic Author
4 years 1 month ago #58163 by manelishi
Test Leads was created by manelishi
Hi, i just got a uscope and had a question about wether or not scope leads are shielded any better than vom leads. im not having any issues but beings the uscope is about the lowest priced scope out there and i have a nice new set of fluke male to male bannana jack leads that are much longer and flexable it crossed my mind. Are vom leads any less sheilded because they are not meant to display a wave form? Also if there would be an issue with the attenuators because they go on the probe end with the uscope? Normally i would think the Fluke would be better than the leads in the aeswave master uscope kit but only if they are the same animal . Thanks
4 years 1 month ago #58164 by Chad
Replied by Chad on topic Test Leads
Use scope leads with a DVOM. And, I use DVOM leads with a scope, interchangeably. I have not notice any difference/issue.
The following user(s) said Thank You: manelishi
Time to create page: 0.259 seconds
