Checking sensor ref and ground
- Rupert S
- Thank you received: 6
4 years 2 months ago - 4 years 2 months ago #57974
by Rupert S
Checking sensor ref and ground was created by Rupert S
Hi everyone,
My first post on here.
Question,
When checking the 5v reference and ground on a Hall effect sensor,
Taking a test light from battery + to sensor ground the light is fairly bright . But when taking the test light from battery– to the 5v reference the bulb isn’t as bright.
Is there a reason for this?
Many thanks
Rupert S
Edit: I’ve just realised I’m putting 5v through the test light when checking the ref and 12v when checking the ground!
Question,
Many thanks
Rupert S
Last edit: 4 years 2 months ago by Rupert S.
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 2 months ago #57975
by juergen.scholl
Replied by juergen.scholl on topic Checking sensor ref and ground
When measuring between B+ and sensor ground the voltage/difference in potential is full system voltage (12V) with the engine off.
The voltage/ difference in potential between sensor reference voltage and B- is only 5V. The lower voltage available makes the testlight shine dimmer in this case.
- Rupert S
4 years 2 months ago #57985
by Rupert S
Replied by Rupert S on topic Checking sensor ref and ground
Thanks, I realised my stupidity about 5 min after posting the question and couldn’t see a way of deleting it.
- juergen.scholl
4 years 2 months ago #57986
by juergen.scholl
Don't worry, we all do have our moments of glory :lol:
