GDI carbon build up
- jimdandy327
- Thank you received: 4
It takes a few applications, and the engine doesn't like it (since the fluid itself doesn't burn), but it's been effective in fixing cold start misfires on GDI engines.
- Ro-longo
- North Salt Lake, Utah
- Thank you received: 43
- Dylan
- Belgium, Europe
- Thank you received: 327
Ro-longo wrote: I just had a Mazda GDI that had carbon build up on the valves in the shop today. It was causing a slight misfire at idle (non turbo). I had already made a walnut blaster with a Harbor Freight sandblaster with walnut media. Cost less than $100 to build. For the business end I used a long metal valve stem that I hollowed out and I use a large diameter heater hose for the vacuum attachment. Does a real good job of cleaning that valves. I made it for a Mazda with a turbo that would backfire through the intake under boost. I will have to take some pics when I get back to shop.
Cool! I've heard of this before but never actually seen it. So definitely post some pics
I was having a similar discussion the other day, and we got somehow to the point of wondering if maybe a fine misting of just regular water through the throttle body or intake vacuum would kind of steam clean the backs of the valves.
I know it sounds counter intuitive, but I can remember seeing some old timers pour water very slowly into carbureted engines for a decarbonizing effect.
Engines running on LPG or CNG also suffer from intake valve issues due to the dryness of the fuel. To overcome the problem in r engines that are particularly you can buy kits to inject metered volumes of upper cylinder lubricant into each intake port.
- jimdandy327
It sure would be a nightmare to wreck a turbo during a relatively routine maintenance procedure...
- Ro-longo
First image is of the tank .
Here is the Vacuum hose adaptor
A view of the nozzle made from a long metal valve stem that I drilled out.
A view with everything put together
And this is from the first time I used it on a Mazda 4 cylinder GDI Turbo. The valve on the left if after cleaning and of course the one the right is before using the blaster. I had previously tried to clean the valves by soaking them over night in Seafoam (It didn't do anything but make a mess)
- Ro-longo
20 lb. Pressurized Abrasive Blaster
25 lbs. Walnut Shell 24 Grit Fine Abrasive Media
I added a water separator that we had in the shop, without it the nozzle would clog up.
I need to add a pressure regulator to the set up,
Ro-longo wrote: Here are the links for the parts
That's pretty slick, sir.
- Dylan
- Belgium, Europe
