eSCAN ELITE with Tablet from ATS
  • Mechanic 350
  • Mechanic 350's Avatar Topic Author
4 years 4 months ago #56836 by Mechanic 350
eSCAN ELITE with Tablet from ATS was created by Mechanic 350
Looking to invest in this tool. Anybody posses this tool that can speak a little bit about it. Does it posses bi-directional control?
4 years 4 months ago #56837 by Noah
Replied by Noah on topic eSCAN ELITE with Tablet from ATS
I'm pretty sure Chad has the E Scan.
I don't think there's any bidirectional controls since it's generic OBD2, but it does have some built in software that will allow you to run VE tests and some other things.
  • Mechanic 350
4 years 4 months ago #56838 by Mechanic 350
Replied by Mechanic 350 on topic eSCAN ELITE with Tablet from ATS
Thanks Noah
  • Mechanic 350
4 years 4 months ago #56839 by Mechanic 350
Noah so how do I contact Chad?
4 years 4 months ago - 4 years 4 months ago #56843 by juergen.scholl
Replied by juergen.scholl on topic eSCAN ELITE with Tablet from ATS
You may send him a pm.
Last edit: 4 years 4 months ago by Chad. Reason: Changed quote color from black to white
4 years 4 months ago #56845 by Chad
Replied by Chad on topic eSCAN ELITE with Tablet from ATS
The eScan is an awesome tool. However, I would not recommend it as a PRIMARY scan tool. As, Noah pointed out, it does not have bi-directional control, and the refresh rate of viewing Data .pids is not the greatest. But, when it comes to solving drive-ability problems, the eScan has some great tests that will help, quickly, determine if the problem is Air, Fuel, or Mechanical. It will plot fuel trim in an easy to read table that allows you to see the "Big Picture" of fuel trim, at a glance. An easy to use Volumetric Efficiency test quickly assesses the engine's ability to breath. Combine those two tests together, by comparing Fuel Trim with Volumetric efficiency, and a drive-ability problem can, quickly, be determined if the cause of is Air or Fuel. It, also, has many other useful tests. Such as a Relative Compression test, Catalyst Efficiency, and others. In short, I would encourage anyone to purchase the eScan. Just not as a PRIMARY scan tool. :)
  • Mechanic 350
4 years 4 months ago #56848 by Mechanic 350
Thanks for the clarity about the tool Chad. That was cool. I’m a diyer not full time mechanic. My primary is an Autel 908 that I have. Thanks again buddy.
4 years 4 months ago - 4 years 4 months ago #56849 by Chad
I should point out that the Volumetric Efficiency test requires a MAF sensor, making it un-usable on Chrysler vehicles (or any other speed density engine). :(
  • Mechanic 350
4 years 4 months ago #56850 by Mechanic 350
That’s correct Chad. Ah, you can’t get everything
