Volkswagen 1.6i strange problem - Fixed
  • Ash03
  • Ash03's Avatar Topic Author
9 years 8 months ago - 9 years 3 months ago #5927 by Ash03
Hi guys. I have a problem with a customers car. Its a vw polo 1.6 8v. It has a Bosch Motronic MP9.0 ecu. It doesn't have much electronics seems to be a very simple system yet its confusing me.
This car has a 8 pin TPS with a built in idle control stepper motor, 4 pin map sensor with a built in air temp sensor, 4 pin water temp sensor, 3 pin distributor and a 3 pin knock sensor. IT DOES NOT HAVE A CRANK AND CAM POSITION SENSOR.
The car came in with a bearing knock, fluctuating idle and a bad over fueling issue.
Before stripping the engine apart I scanned for dtcs and I found 2 Codes
1. Map sensor short to positive
2. Air intake temp sensor short to positive
I cleared the codes. Overhauled the engine. Started the car up again with the same sensor and I got the same dtcs and symptoms (fluctuating idle and over fueling)
So I unplugged the map sensor connector and did a few tests
1. Checked for 5v reference on the map and air temp wires - was good got 5.01v on both wires
2. Checked for ground - was good as well
3. Signal wire has 5v (i believe the voltage varies depending on sensor output)
So basically the wiring is OK.
I tested the sensor next. Sensors output value was the same irrespective on the vacuum applied to it (it also smells burnt) so I replaced the sensor with a new part.
After fitting on the new map sensor the car is still behaving weirdly.
The problem the car has now - it starts up and dies after a second. It cannot idle. It revs up as if starving for fuel and cannot rev unless the throttle is open wide (WOT) but it does not throw any dtcs.
If the map sensor is unplugged, the car can start and idle the same as with the damaged sensor (fluctuating and over fueling)
If the TPS is unplugged and map is plugged, the car will start rev up fine, no over fueling it just doesn't idle as the idle control is built into the TPS.
So I decided to test the TPS and it also works 100%
Now im starting to get worried as I don't know what's going on.
I then decided to get an ecu pinout and test all wires from ecu plug to the specific component that's being fed by the ecu.
All turned out 100% no open circuits or shorts in the wiring.
The car has no vacuum leaks, the timing is 100%, has proper fuel pressure.
Can somebody please help me any input will be greatly appreciated.
Last edit: 9 years 3 months ago by Ash03.
9 years 8 months ago #5934 by mreyes92
Year
9 years 8 months ago #5936 by Doc n2mx
Hi ,
Can you give the vin and year?
you tested the wiring I was wondering just how you did this , did you use a load or just a ohm meter?
Doc N2mx
  • Ash03
9 years 8 months ago #5937 by Ash03
Im not 100% sure of the year but, its either a 1997/1998
Vin AAVZZZ6KZVU008183
Sent from my SM-G531H using Tapatalk
  • Ash03
9 years 8 months ago #5938 by Ash03
Doc n2mx wrote: Hi ,
Doc N2mx
I first checked the voltages on ref wires with the key on engine off..
Then, I tested the loom with it unplugged from the ecu and whatever sensor it went to, with an ohm meter.. the wires tested between 0.1-0.2ohms.
Is there any other way thats more effective?
I watched so many of Pauls videos that I sometime get confused lol ( Im not good with wiring)
  • Ash03
9 years 8 months ago #5962 by Ash03
Anybody?? Need to sort this problem out urgently please
9 years 8 months ago - 9 years 8 months ago #5965 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Volkswagen 1.6i strange problem. Please help urgen
The codes and the first tests you did on the TMAP sensor I think point straight to the issue.
It looks like the MAP output and possibly the IAT wire from the TMAP are shorted to +5v reference the thing you have to test for is if this is in the wiring harness or inside the ECU.
Knowing VW I would suspect a harness issue. With the harness unplugged from the ECU and the TMP check the ressistance between both the IAT output and the MAP output and the 5v reference.
Last edit: 9 years 8 months ago by Andy.MacFadyen.
9 years 8 months ago #5967 by Andy.MacFadyen
I should really explain a bit more.
The TMAP sensor is simply two completely separate sensors built into the same unit, the only wire they share is a common ground.
The IAT side is a conventional thermistor with 5v supply and uses the common ground.
The MAP sensor side has a 5 supply, sensor output and also shares the common ground.
Normally with the sensor unplugged key on engine off I would expect to see roughly:
IAT wire 4.9v to 5v
MAP reference 5 to 5.1 v
MAP output pin close to 0v
Ground Pin very close to 0 volts.
If with the plug disconnected you see more than ghost voltage on the MAP output pin it indicates a short to one of the 5v wires.
  • Ash03
9 years 8 months ago #5978 by Ash03
Hi Andy
Thats what i also thought..
When i tested the output wire, key on engine off i get just a little under 5v. I thought that was my problem.
I searched for data on this vehicle and i found autodata info on the mp9 ecu.
The data states, key on engine off i should get 4v on the map output wire.
I did test the harness as i mentioned but everything seems to be ok hence i asked if there is any other method that i can use in testing the harness (im not so educated in electronics and wirng so u will have to give me an indepth expl lol)
The ecu is mounted placed in the raintray (under front wipers) ecu is aluminium and corroded quite bad im assuming water seeped in and probably shorted something out.
I am failing on this vehicle and i will try any tests suggested
  • Ash03
9 years 8 months ago #5981 by Ash03
Is it possible for me to test ecu wiring in this way without damage to the ecu:
Postive lead on battery+ and negative lead on the 5v ref or signal wire to check for a short to ground?
Is it necessary for a short to ground on a 5v ref to measure 0volts? In other words, can a power wire thats shorted to ground show a voltage close the required voltage?
  • Ash03
9 years 8 months ago #5988 by Ash03
Number 18 is the map sensor output
  • Ash03
9 years 8 months ago #5989 by Ash03
I have a friend with the same managment system though, luckily im out for the weekend close to his place, so i am going to test the wiring on his car and match the values against the troubled car
  • Ash03
9 years 8 months ago #5990 by Ash03
A few more questions:
1. Is there any way to test the ecu by myself? I have very basic tools though (dvom and a 12v test light)
2. What does it mean when the ecu says SHORT TO POSITIVE? Is the signal wire or reference wire being shorted or the short can be either of them and has to be tested?
3. How is the knock sensor tested? This car has a 3pin knock sensor and i noticed there is no 5v ref on any of its wires.
Im not sure if the 5v ref is shared between the sensors as each sensor has its own 5v ref wire. It could be shared inside the ecu.
If it is shared inside the ecu, is it possible for the ecu to be throwing a map code but the problem really lies with the tps or distributor?
9 years 8 months ago #6012 by Ben
You need to check the live data see what coolant temp says air temp etc. does this car have 2 coolant temp sensors? I'm not familiar with this particular model I work on a lot of 1.8t engines does this have a throttle cable or is it DBW if it's DBW than you need a throttle body alignment performed with a vag com . I may be off base here like I said I work on 1.8t I'm not sure what you have and what you don't have on this car
  • Ash03
9 years 8 months ago - 9 years 8 months ago #6030 by Ash03
Hi Ben
The car has one water temp sensor which is a 4 pin sensor. which I believe 2 pins are for the temp gauge in cluster and 2 pins are for the ecu.
It has a throttle cable. And i did do the throttle adaptation anyways, and quite a few times too.
I did view live data on the vehicle after all the testing sorry for not mentioning it.
Via live data (measuring blocks) i get the following values:
Water temp - Liva data water temp matches with cluster temperature and seems to be somewhat the correct water temp.
Air intake temp - when engine is at operating temp, air temp reads +- 50degrees (Celsius)
Throttle position - with map sensor unplugged at idle the throttle position varies from 5-7 degrees(car does not idle with map plugged in neither can i hold the rev any close to idle. if not on WOT the car wants to cut out)
Map - varies from 400-900 mbar with the sensor plugged in (higher rpm = higher mbar)
i will run vcds again and repost the logs just to be 100% sure
Last edit: 9 years 8 months ago by Ash03.
9 years 8 months ago #6055 by Ben
Do you have a ross tech vag com ? There is some good info on the ross tech website check it out if you haven't already . How about an EGR adaptation kind of a long shot but maybe it is open at idle, it wouldn't make sense to run right with map unplugged if that were the problem though. these German cars are very picky about there inputs.....
  • Ash03
9 years 8 months ago #6056 by Ash03
I have Vcds but I dont think its an original version..i did check ross tech, didnt help me...
This car does not have an egr system or lambda sensor, as I mentioned its a very basic system yet confusing
9 years 8 months ago #6058 by Ben
How did you test TPS with dvom or in measuring blocks? Let's concentrate on the TPS and IAC for a moment KOEO in measurement blocks the TPS is smooth and equal to throttle movement it may not go to 100% but that's OK. if that's good then it may be worth releasing the signal wire from that connector so the IAC will be connected but the TPS won't be and see if it idles and runs ok that way . Currently there is no CEL or pending codes? If it will run with the TPS disconnected then try to drive it and see if you can get anything besides the TPS circuit code
  • Ash03
9 years 8 months ago #6059 by Ash03
I tested the tps via vcds and using a dvom back probed into the tps plug.
Throttle opens smoothly on measuring blocks - max limit 87degrees
Voltage also increases smoothly when using a dvom - max limit around 4.5v
With all sensors plugged in, and fault codes cleared from previous unplugged sensors, no codes reappear.
This vehicle does not have an iac solenoid, its has an idle control stepper motor built into the tps, which is built into the throttle body.
The throttlebody has an 8 pin plug
Pin 1: idle control motor +12v
Pin 2: idle control motor ground
Pin 3: closed throttle position switch for idle motor
Pin 4: tps +5v supply/reference
Pin 5: tps signal to ecu
Pin 6: not used
Pin 7: ground (not identified on wiring diagram, but confirmed via the tests i have done)
Pin 8: closed throttle position switch for idle motor
I assume that pin 3 and pin 8 are for minimum and maximum positions, as in min=closed and max=wot
This is not an original wiring diagram from vw (tried to get one but i couldn't), its a diagram that i have found on google after tons of searching and seems to be the most accurate.
So do i disconnect pin 5 and then try?
9 years 8 months ago #6060 by Ben
Yes try with pin 5 removed also verify that the throttle closed switch is working I'm not sure on this model but usually it will be between.0 and .2 volts with throttle closed and will jump to 5.0v when slightly opened and stay at 5.0 all the way to WOT
Time to create page: 0.394 seconds
