Volkswagen 1.6i strange problem - Fixed
- Ash03
- Thank you received: 6
The throttlebody wiring was tampered with and i found the following values from my recent test
Key on engine off - testing throttlebody wiring
Pin 1: idle control motor +12v - 0v
Pin 2: idle control motor ground - 0v
Pin 3: closed throttle position switch for idle motor - 11.8v
Pin 4: tps +5v supply/reference - 5.03v
Pin 5: tps signal to ecu - 5.52
Pin 6: not used
Pin 7: ground - 0v
Pin 8: closed throttle position switch for idle motor - 5.52v
Key on engine on
Pin 1 - varies around 2-13v
Pin 3 - snapping the throttle 8-13v
Pin 8 - constant 3.4v
Sensor ground on pin 7 was way too loose and broke off when i touched it, I am going to sort that out and retest. I honestly have no direction with this car and don't know what to expect next.
- Ben
- Thank you received: 215
- Ash03
- Ben
- Ash03
The car had alot of people working on it though, had a distributor problem, starter problem, alternator problem, all of those parts were changed with aftermarket pirate parts.
I did clean the entire throttlebody.
The voltages on the closed throttle position switch is confusing me.. Common sense tells you that there should be a closed throttle position switch and an open throttle position switch, and thats the reason I dont want to rely on the pinout info that I have.
I was unfortunate that i could not meet my friend who has a similar vehicle to do a few tests on his car
- Ben
- Ash03
Isnt the idle control motor a pwm circuit? (pulse width modulation)
- Ash03
- Ben
wiki.ross-tech.com/wiki/index.php/Throttle_Body_Alignment_(TBA)
- Ash03
And i did it every time I disconnect the tb, made no difference
- Ben
- Ash03
What do you mean by check the ecu to make sure its not the second one?
- Ash03
And the tb does cycle for a few seconds
- Ben
- Ash03
- Ash03
- Ash03
If I disconnect Pin1 from the ecu plug and put a direct 12v onto it, I noticed that the stepper motor moves back and forth rapidly causing thee idle to fluctuate even more, so I am guessing that Pin1 is not suppose to have a constant 12v supply and the ecu probably regulates the voltage according to other signals.
I think we need to know how this component actually works in order to find the problem.
I will however try to get a decent throttlebody plug tomorrow, reconnect all the wires and then check from there, because there could be bad connections on the other wires causing a voltage drop somewhere across the line therefore correct values are not being sent to the ecu or to the tb.. (I dont know if that makes sense, does it?)
- Ash03
- Ben
- Ash03
