FIXED 99 Durango
  • Globeville
  • Globeville's Avatar Topic Author
5 years 11 months ago #44483 by Globeville
99 Durango was created by Globeville
My 99 Durango, 157,000ish, is a no crank, no start. Since issue started: New battery. Replaced ignition switch with one from the pull and pay. Bypassed the relay and started right up, but still no crank no start with the key. Issue: Leaving for work early 2020, snowy day and it wouldn't start. Tried roadside for a jump and nothing. Tried new battery first. Still no crank no start, but the horn would honk when I would crank. I removed the horn fuse so I could continue to troubleshoot without bugging neighbors. Only thing I really did is replace the ignition switch with a used one. Other than new battery and bypass the relay. I'm just a level 0 do it yourselfer. I probably could have made this message shorter. I need help! Thank you in advance!
5 years 11 months ago #44537 by Tyler
Replied by Tyler on topic 99 Durango
Well done with the relay bypass. B) That answers a lot of questions about the starter and electrical system. Have you tried cranking the engine with the shifter in Neutral instead of Park?
The following user(s) said Thank You: Globeville
5 years 11 months ago #44550 by Hardtopdr2
Replied by Hardtopdr2 on topic 99 Durango
Replacing lock cylinder with a used or new one you may need to do a anti theft relearn.
  • Globeville
5 years 11 months ago #44560 by Globeville
Replied by Globeville on topic 99 Durango
Thank you!Yes I have tried to crank in neutral. I will again to double check. Keyless entry works. Almost replaced the starter before bypassing the relay.
  • Globeville
5 years 11 months ago #44561 by Globeville
I can't remember if the ignition switch had the lock cylinder. Fuck I'm stupid. How do I do the antitheft relearn?
5 years 11 months ago #44563 by Hardtopdr2
If you have access to service info it will tell you. Ie Mitchell or alldata see below. I would recommend you do the 30 min relearn as my experience is the short one never works.
www.eautorepair.net is the Mitchell site
www.alldatadiy.com
  • Globeville
5 years 11 months ago #44564 by Globeville
Thank you! I will have to try! Did you mean the door lock cylinder or the ignition lock cylinder? Just curious!
5 years 11 months ago #44565 by Hardtopdr2
Ignition lock cylinder as some vehicles have a rfid chip or incoded key that sends a signal to bcm to say ok to crank engine and start vehicle. Do you have a anti theft light flashing?
  • Globeville
5 years 11 months ago - 5 years 11 months ago #44592 by Globeville
Not in the dashboard lights, but there is what looks like an auxiliary port, headphone port, with a red light that sits just under and to the right of steering wheel. I'm not sure if that is stock or aftermarket. That light flashes all the time. I read somewhere that the blinking led is also a button.
Last edit: 5 years 11 months ago by Globeville. Reason: More thoughts!
  • Globeville
5 years 11 months ago #44596 by Globeville
No crank, no start while in neutral also.
  • Globeville
5 years 11 months ago #44600 by Globeville
This thing. Not sure if it's aftermarket or not. Flashes even after I've used the keyless entry fob to unlock the doors.
5 years 11 months ago #44601 by Hardtopdr2
No idea what that is. I would follow the wires and see if it was tapped into the dlc or obd port if so that might be the issue but i kinda doubt it.
5 years 11 months ago #44602 by Matt T
Replied by Matt T on topic 99 Durango
Globeville wrote: This thing. Not sure if it's aftermarket or not. Flashes even after I've used the keyless entry fob to unlock the doors.
That thing looks like it might be an aftermarket immobilizer that requires something plugged into it.
  • Globeville
5 years 11 months ago #44604 by Globeville
WTF! How do I find that shit!? Thank you!
  • Globeville
5 years 11 months ago - 5 years 11 months ago #44605 by Globeville
Replied by Globeville on topic 99 Durango immobilizer help
What the heck, f@#$, is this thing! No crank, no start.
5 years 11 months ago #44606 by Hardtopdr2
Just follow the wires going from it to under the dash. 2 wires from immobilizer will be connected to the start signal wire. Just get pics of what the wires connect to and we can walk you through removing it.
  • Globeville
5 years 11 months ago #44607 by Globeville
I will have to do it tomorrow! Is there anything you or anyone else can tell me about this damn thing?
5 years 11 months ago #44621 by Noah
Replied by Noah on topic 99 Durango
I wouldn't give that little thing much of my attention.
Like mentioned before, follow the wires, see where it goes. If there's a black box like for a remote start or alarm, unplug it.
Please don't open multiple threads for the same problem.
Thanks!
Noah
  • Globeville
5 years 11 months ago #44622 by Globeville
Okay, apologies and thank you! Is there anyway you can delete the other thread?
5 years 11 months ago #44645 by Noah
Globeville wrote: Okay, apologies and thank you! Is there anyway you can delete the other thread?
No worries, common occurrence ;)
