Both banks running rich under no load,
- Richard1
5 years 7 months ago #42531
by Richard1
Both banks running rich under no load, was created by Richard1
2011 QX56 Infiniti 5.6L
Fuel trims -10 to -16 under no load
on Cruise at 50mpg fuel trims -6 or so both banks
Exhaust smells of fuel when stopped
Injectors difficult to get to need to remove the intake manifold.
Once in a while I get 1 miss fire on one cylinder or another but not common
All plugs are new
Low pressure fuel pump is new
Overnight the fuel pressure drops and I must wait in the morning for pressure to build up with key on before start otherwise a P0087
Running out of ideas any help appreciated.
Richard
All plugs are new
Richard
- Jesh
- Thank you received: 4
5 years 7 months ago #42733
by Jesh
Replied by Jesh on topic Both banks running rich under no load,
is this a returnless fuel system, or does it have a regulator?
- Richard1
5 years 7 months ago #42739
by Richard1
Replied by Richard1 on topic Both banks running rich under no load,
Hi Jesh
It does have a pressure regulator on the fuel rail. I do have a regulator on order but where I live it takes a couple of weeks to get it.
- Dtnel
- Thank you received: 67
5 years 7 months ago #42743
by Dtnel
Replied by Dtnel on topic Re:Both banks running rich under no load,
What are you going to the injectors for right now? What's labor time on that? Might be cheaper to have a shop hook a scope up to it if you don't have one.
There's so many tests you can do these days without having to remove the complicated myriad of things to get below the manifolds. I'd explore other options.
Sent from my SM-N975U1 using Tapatalk
- Dtnel
5 years 7 months ago #42744
by Dtnel
I wouldn't throw parts at it.
Have you checked it for engine codes? Where the heck you live where it takes two weeks if you don't mind me asking? Hawaii? Alaska?
- Richard1
5 years 7 months ago #42745
by Richard1
Replied by Richard1 on topic Re:Both banks running rich under no load,
I'm inPanama.
When i order it goes to Miami from there to
Customs in Panama then I can pick it up.
A pain in the ....
A pain in the ....
- Jesh
5 years 7 months ago - 5 years 7 months ago #42746
by Jesh
pull off the vacuum hose that goes to the fuel pressure regulator and see if its wet inside/ smells of fuel, if you have a torn regulator diaphragm you might be leaking fuel into the intake via the vacuum hose.
Also, did this problem start before or after the fuel pump was replaced?
Last edit: 5 years 7 months ago by Jesh.
- Richard1
5 years 7 months ago #42752
by Richard1
Hi Jesh
Problem was there before I replaced the low pressure fuel pump in the tank.
This pump is not connected to a vacuum as the pressure goes above 600psi sometimes according to the scanner.
The actual pressure is almost always different then the commended pressure by the pcu sometimes 60psi higher sometimes lower, which leads me to believe it might be the pressure switch its located right at the end of the fuel rail and electrical only.
I was told today the part cleared custom ill be picking it up tomorrow. Keeping my fingers crossed that its the right part.
