Lean codes bank 1 and 2. 2003 Sienna
- Flykol6
- John Curtis
- Thank you received: 111
Can you read freeze frame data? What does it show?
I’d prefer PID values over graphing if possible
What are fuel trims at idle?
What happens when you increase the rpms at idle holding at 2500 and 3000 rpms? Do they get better? If so, vacuum leak.
Do your oxygen sensors go full rich during WOT on the road?
What is MAF reading at idle in grams per second?
- Flykol6
Lets see if I can answer your questions.
FT at Idle STFT1 = +5, STFT2= -8 , LTFT1 +20, LTFT2 +19
LT Fuel trims do get better when I Increase RPM.
AT 1200 RPM Long Term is 22
AT 2000 RPM Long Term is 10
Short term jumped around a lot , I did not see a noticeable change.
Oddly the start up Idle was at 2000, unusually high today.
Cold Idle @1200 RPM Maf was 5.7
After a few minutes @ 800 RPM MAF was 2.65. Engine is a 3.0L
I'm not sure what PID values are. Is that the voltages, or just the numbers reported? My OBD2 is WIFI read by my phone.
I am not sure how to tell if O2 goes fuel rich at WOT.
From your reply. It seems I have vacuum leak that I cant find. So far I've checked rubber intake snorkel 2 times. hose clamps are tight. Replaced one crispy vacuum line to valve cover. I have not checked brake booster yet
My MPG is great 26 to 28.
- Paul P.
- Thank you received: 195
I'd also like to see the A/F sensors go rich during a WOT run through first gear, and see them go to full lean during a fuel cut deceleration. What PIDs do you have available for the upstream (B1S1 and B2S1) sensors?
- Flykol6
- Flykol6
- Flykol6
- Flykol6
- Paul P.
Using a propane torch, unscrew the Air/fuel element at the burner end of the torch and add a nice length of rubber hose. This makes it possible for you to leave the propane on (gently) just a small hiss with the can remaining upright. On the other end move the hose SLOWLY all over the intake manifold area, Canister Purge valve, all vacuum lines, while monitoring the STFT's. When Propane gets 'sucked' in the STFT will immediately respond by going Negative. Don't be fooled by a false positive if the propane does enter the air tract properly. You can actually try that first as a test so you can see the response time for the trims. That will give you an idea of how slow to move the hose.
Based on your fuel trims responding by getting better at higher engine load/rpm, I would tend to believe fuel delivery is adequate, otherwise, they would be going Positive at higher load/RPM due to lack of volume/pressure or restriction.
If the MAF was underreporting, 'dirty', your trims would go further Positive at high load/rpm.
Never stop Learning.
- John Clark
- Thank you received: 46
For checking fuel delivery I find it helpful to graph the TPS and both upstream O2's at the same time. Then you can correlate your wide open throttle event with the O2 sensor data. On Toyota you need to be careful, though, as many use air/fuel ratio sensors which work different than a traditional narrow band O2 sensor. When you mash the accelerator, your O2 sensors should go full rich, or around 800mV and stay there the duration of the wide open throttle. If the drop lean then you could have a MAF or fuel deliver issue. You don't need to overrev the engine but just give it 3-5 seconds of wide open throttle.
If your vehicle has air/fuel ratio sensors for the upstream sensors then reading those is a bit different than a traditional O2 sensor. You have to watch the voltage on the scan tool and voltage above 3.3v is lean and below 3.3v is rich.
- Flykol6
- John Clark
- Paul P.
If you rule the fuel system out for John, rule out a breathing issue, then we can focus on the vacuum leak.
- Flykol6
- Cheryl
- Thank you received: 215
- Flykol6
From the looks of things I should have bullet holes in the intake.
- Flykol6
- Flykol6
- Cheryl
