P0122 TPS GM 4.3 / Low voltage on ref. & signal
  • Westfalia
  • Westfalia's Avatar Topic Author
10 years 2 months ago - 10 years 2 months ago #389 by Westfalia
P0122 TPS GM 4.3 / [FIXED!!] was created by Westfalia
1997 Chevrolet Astro 4.3 Vortec V6
KOEO measured .14v on 5v ref. wire(gray) and .03 to .1 v on signal wire(blue) when throttle moved slowly. This is measured on a multi meter. Ground is good and measures 40 mili volts. Truck starts and runs, but fault is constant and immediately comes back when cleared. Idle is high and throttle is a bit sluggish like you'd expect from a bad TPS. I watched the TPS videos, but they all start with a good 5v reference. I'll rewatch.
Question: Is the sensor good because I see a voltage change, even though it is way too low? Where should I be looking to see where my full 5 volts went? Will they come back when I put a new TPS in or should I be looking at a short in the ref wire. BTW, the instrument cluster gauges are all pegged waaay past their limits. Could that be related?
Thanks!
Last edit: 10 years 2 months ago by Westfalia.
The topic has been locked.
10 years 2 months ago #390 by GeorG
Unplug the TPS connector and see if 5 volts come back on your 5 volt ref wire. If there's still no 5 volt, you can jump the MAP's sensor 5 volt to the TPS ref wire using a 5 Kohm resistor. If TPS connector wire now has 5 volts, you have an open in the wire,if not then you have a short.
Please provide with year make and model so we can review the wiring schematic, and see what else is on there.
  • Westfalia
10 years 2 months ago - 10 years 2 months ago #398 by Westfalia
Replied by Westfalia on topic P0122 TPS GM 4.3 / Low voltage on ref. & signal
Sorry. 1997 Chevrolet Astro Van 4.3 vortec V6
No 5v when unplugged. I've yet to see if the MAP has 5V. I forgot to mention that I also had a P1406(EGR pintle) fault code. I pulled it and it was not clogged up (just recently had the IM off and thoroughly cleaned the passage too. I looked at the diagram and fuel sender gauge module and the EGR share a gray (reference?) wire. Possible reason all the gauges are pegged??
I have measured voltage at all the listed 5v. ref. wires at the VCM (pins 12 and 21 on the WHITE connector with KOEO) and I'm only getting less than a volt. I have a known good computer. I put it in, and the condition is the same but did not have time to test it's 5v pins. Highly doubt I have two bad computers though. I'll test it tonight.
Thanks.
10 years 2 months ago #400 by matt.white
Replied by matt.white on topic P0122 TPS GM 4.3 / Low voltage on ref. & signal
Not being in the states I have no access to Astro data sorry but I'd look at what else runs on that 5v reference circuit and see what's pulling it down. So there's only two reference circuits and they're both low? I'm amazed it runs. If you definitely have low reference at the ECU you need to unplug everything on that circuit one by one and see if it rises. Obviously if it jumps up then you've found a short. If not you need to find if the circuit is shorted to ground or whether the 5v supply is bad from the ecu.
10 years 2 months ago #401 by Noah
I agree with these guys, you need to find out what is going on with the 5v reference circuit. There's a bunch of videos on this subject if you click the YouTube videos tab at the top. There all embedded right in this website which makes it easy.
This one covers testing a tps on another GM vehicle, hope it helps.
There's another one demonstrating the test Georg is describing with a resistor. That's a real good test, you can use a test light to substitute the resistor if you must.
Im curious to see how the 5v ref circuit looks with the known good pcm considering you happen to have one and it won't cost you anything to try it.
  • Westfalia
10 years 2 months ago - 10 years 2 months ago #411 by Westfalia
Thanks for the suggestions guys. I've watched those, but unfortunately he does not address what to do if the reference signal is not 5v and where to go from there.<edit> Watched again and he does show what to do, but found an obvious fault on the harness not tracing a open in a harness. I'll try your suggestions and get back to you once I get home and dig in...again :(
I'm using Mitchell1diy diagrams. There are 4 pages of diagrams and I'll try to link them here. Not sure if they will work. On page 4, at the right most portion of the whole diagram you can see the two 5v ref. pins (12 & 27). They are in the WHITE connector. There are 4 connectors on this VCM (WHITE,BLUE,RED,BLACK). This diagram(page 4) contains the WHITE (top)(pins1-32) and BLACK (bottom) (pins 1-24)connectors. Oh there is a 5th connector a 4 pin BLACK square, but it is just a loop through for the service circuit provider. Is that for a scanner connection??
<edit>I found a way to post the entire set of 4 diagrams. They should be laid out L to R(1-4) if you print them out. ;)
Page #1
Page #2
Page #3
Page #4
Computer
10 years 2 months ago #412 by Noah
If you're a premium member or if you have the book, there's lots of material covering the 5v ref circuit. This is part 1 of a 3 part series involving a Jeep which, although exhibits different symptoms, does not have 5v at the tps. It kind of walks you through Paul's thought process when the ref circuit is down.
I would start by checking for 5 volts on another sensor. If you still don't have it, time to look for a shorted circuit to ground with the ohm meter.
Of course powers and grounds at the VCM are suspect it the 5v ref doesn't check out, but your vehicle runs...
Those computers are notorious for connector issues and pin fitment problems. I've had to repin more than a couple connectors on that style VCM.
It's not popular with many Tech's, but if I don't find 5v at more than one sensor, I like to go ahead and cut the 5v wire coming right out of the vcm and check voltage there. If you got nothing, check computer power and grounds, (and check the connector for bent pins or corrosion),then if all that checks, it's computer time.
If you do have 5v at the computer after cutting the wire, then you need to start looking for a shorted sensor, or possibly a shorted out partly shorted wire to ground.
  • Westfalia
10 years 2 months ago #414 by Westfalia
Heading out now to give it another shot. I'll try those things. Thanks for the tips. I'll post back what I find.
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
10 years 2 months ago #416 by ScannerDanner
Replied by ScannerDanner on topic P0122 TPS GM 4.3 / Low voltage on ref. & signal
exactly the videos I was going to post Noah! Thanks!
Don't be a parts changer!
  • Westfalia
10 years 2 months ago #421 by Westfalia
I'll re-watch them. I'm sure I missed something. Thanks.
  • Westfalia
10 years 2 months ago - 10 years 2 months ago #423 by Westfalia
Noah wrote: If you're a premium member or if you have the book, there's lots of material covering the 5v ref circuit. This is part 1 of a 3 part series involving a Jeep which, although exhibits different symptoms, does not have 5v at the tps. It kind of walks you through Paul's thought process when the ref circuit is down.
Ok, so some more work yielded not much progress, well maybe a bit. So, I checked for 5v ref. on other sensors. All are within 1/100 of a volt. Right around .12v. Measured this at every sensor(EGT,TPS,Fuel Gauge,MAP) on both the 5v circuits(I understand they are all really one, but with two outs of the computer). Measured TPS and has linear resistance with no hiccups in ramp up or down.
TPS- Gray(ref.) .14v
Black(gnd.) 100mv
Blue(sig.) .05v
MAP: Black(gnd.??) .37v
Lt. Green (sig.) .0v
Gray (ref.) .12v
I back probed and measured voltage on both reference wires at the WHITE VCM plug (pins 12 and 27 at the computer) and the low voltage is the same as is measured at each sensor. I unplugged each sensor and had the voltmeter watched...no change. 12.4 v measured TO the computer at the B+ input pin 21(WHITE connector orange wire). No evidence of damaged/corroded pins on VCM or expanded plug pins.
As mentioned above I have a spare computer. I installed it and all the measurements are the same. The odd thing came when I went to start it using this "good" computer. The engine barely sputtered, and would not run. I put the original computer back in and it runs and idles well, but not perfect(slight stutter upon revs). Hard P0122 still there and will not clear. 2 bad computers...broken differently??
I know you mentioned testing the reference line for a short with an ohm test. Forgive me, and I know this should be 101 type stuff, but exactly how do you do that? Embarrassed to say I don't know. I'm sure paul has a video of it somewhere..I'll look too.
As usual, thanks to all for any input. Very close to the nuclear option now...
10 years 2 months ago #461 by Tyler
Sorry I'm late to the party on this one, but is this the same Astro that was having short to ground problems and blowing fuses? We had a thread going on the old forums before we moved, couldn't move it with us :(
Given the voltage measurements you have at pins 12 and 27 at the VCM, I'm really surprised you only getting a TPS code right now! Like Paul said, having low voltage suggests a short, yet the van runs. I've clipped the 5V reference wire close to the PCM before, and I think it's perfectly valid when chasing problems like this.
I'm wondering if you're not chasing some green corrosion in the VCM connector, causing a voltage drop right at the VCM. Maybe have a careful look at the female pins in the connector, or even consider taking that pin out of the connector for a closer inspection?
  • Westfalia
10 years 2 months ago - 10 years 2 months ago #469 by Westfalia
Tyler,
Yeah it is. None of that old thread we were working on could be migrated I was told. I forgot to mention it was the same problem child.
I had a bit of help from a shop and they told me "oh, it's the spider that's shorting things" and once the multi pin plug was disconnected from the injector (this has Central multi point) the short goes away. (BTW I could swear I did disconnect the EFI plug when I was trying to diag. the short, but I could have not had the key on or some other bonehead move as I was chasing my tail seeing as I really new at all this.)
Great I said. I Got a new spider(it was needing to be replaced anyway) and when I put the new one in and buttoned it up, the short was gone. I figured all is good. Turn the key on and the pump springs to life and we have DLC com, and it appears that the ECM-1 circuit is perfectly fine. Crank and it starts, but now I get the P0122 code and an EGR pintle code and a slightly rough rev. I pulled the EGR and checked it over put it back in and that code went away. We pick up the story over here on the new site.
So when I clip that wire(5V ref. GRAY) what am I looking for and where do I measure it at? I don't own a scanner btw. I guess before I do that, I'll put a tracer on that wire and hunt for a short.
The connectors look brand new with absolutely no corrosion. I'm in Southern CA and I think it rained about 9 months ago...maybe ;-) Corrosion is not one of our bigger problems. Heat is though.
10 years 2 months ago #470 by Noah
Clip it an inch or two from the VCM, really just somewhere that you'll be able to make a quality repair close to the VCM when you're done. You said there's two? Clip them both. Measure right at the little wire you left sicking out of the VCM with the negative lead of your multimeter at battery negative.
Scanner Danner has an awesome video, I think on a cobalt maybe? Checking for a 5v short to ground... I gotta do some searching to find it, I'll try to post it up tonight.
10 years 2 months ago #471 by Noah
You need to do a security relearn procedure before the van will start with the other VCM.
It takes some time, about 30 minutes. Sometimes it doesn't take and you need to do it again...
basically, turn the key to the ON position (without cranking). The security lamp will illuminate and stay lit for about 10 minutes. When it switches off, turn the key off and wait 5 seconds.
Then turn the key to the ON position again, wait for the lamp to go out again, key off for 5 seconds again.
Then, turn the key to the ON position again. If the lamp comes on, then shuts off, the van will start. If not, just ANOTHER 10 minutes until the lamp goes off.
So that's 3 ten minute on cycles. After that, when you turn the key on, the security lamp should illuminate for a couple seconds, then go out. The van should start.
If the lamp stays illuminated, it won't start.
  • Westfalia
10 years 2 months ago - 10 years 2 months ago #473 by Westfalia
I really appreciate your help and follow through! It'll be till Sat before I try again. Flat on my '01 Audi. I'm down to a '62 VW bus now...lol. Someday I'll learn and buy a Toyota or Honda. Haha.
I just came back in and am just now reading you instructions about cutting the 5v ref. wires. After prodding/poking/moving/wiggling every bit of harness I could lay my hands on, that .15-.16 of a volt was about as solid as the Hoover Dam. Did not move at all. I also could not find any breaks or abrasion at any point(visible) on the harness. There is talk over on the Astro forum of a fault on the backside of the compartment side pass through. I've yet to figure out how to remove it, but wiggled the crud out of that area to no avail. I'll see if I can find a link to my post over there. I might have posted it on that other thread. It was a 12v power feed to the VCM though.
Here is the link to the thread, hope it works. Down about 1/2 way on page 1.
www.astrosafari.com/viewtopic.php?f=43&t=100745
10 years 2 months ago #476 by Noah
Here's the cobalt video I was thinking of. I re watched it to make sure it was the one. Unfortunately, he didn't get to the point of checking the 5 volt reference circuit for a short to ground.
Pretty much, with the sensors disconnected and the VCM disconnected, put one lead of the OHM meter to battery NEG, and the other lead to the 5v circuit at the VCM connector. The only acceptable reading here would be OL kOhms. Or 0 continuity. Hope that makes sense.
  • Westfalia
10 years 2 months ago #494 by Westfalia
Noah wrote: Here's the cobalt video I was thinking of. I re watched it to make sure it was the one. Unfortunately, he didn't get to the point of checking the 5 volt reference circuit for a short to ground.
It does. I'll try tonight. Thanks.
  • Westfalia
10 years 2 months ago #495 by Westfalia
This is a '97, I don't ever remember having a "security" light. I'll try it though. The van starts with one of the computers, it just has a P0122 code and super low ref. voltage.
  • ScannerDanner
  • Administrator
  • Administrator
10 years 2 months ago #513 by ScannerDanner
I definitely did Noah, start watching around 38 minutes in. I check the sensors for a short to chassis ground and a short to the sensor ground. I just did it without unplugging the other sensors due to location.
