89 Chevy Silverado issues.
  • wacoeagle
  • wacoeagle's Avatar Topic Author
7 years 1 month ago #27430 by wacoeagle
Replied by wacoeagle on topic Re:89 Chevy Silverado issues.
you know come to think of it, when we got the engine put all back together, we didnt even realize the map sensor was missing, we knew there was a plug connector not hooked up, but we were curious to see if it would run. we started it and it Idled great. It wasnt until we went to the junkyard, figured out what was missing and eventually put the map sensor and whatever else is on that bracket on. it seems like the idling problems then started. I also didnt realize the vacuum line from the back of the TBI wasnt hooked up, it wasnt even there. yet the truck idled fine, with that vacuum leak and no MAP sensor.
Im thinking that some of the vacuum circuits in the TBI Are critical to vacuum pressure and some are not,. take the pcv valve, it sucks in an enormous amount of air. I cannot see where this would be calculated into the engine management control. it is almost an open vacuum stream. why the engine idled great with the map sensor missing and a huge vacuum leak at the back of the tbi is strange.
it also had the missing o2 sensor in the manifold at that time.
Maybe it all balanced out somehow.
"" ya know what I think we should do Norton? whats dat Ralph? i tink we should remove dat o2 sensa.."" lol
  • wacoeagle
7 years 1 month ago #27433 by wacoeagle
Im going to check the vacuum line, i THINK TODAY may be the day we figure it out. It would be just my luck to have gotten a MAP out of the junkyard and its bad.
would a scanner that reads OBD1 have seen this from the beginning? would it show the map voltage hopping around? or just quickly fluctuating fuel trims.?
7 years 1 month ago #27434 by Rockyroad
Replied by Rockyroad on topic Re:89 Chevy Silverado issues.
The otc genisys shows map it’s a real important sensor in non maf motors. You need to keep that o2 sensor in the manifold. It doesn’t start working till around 600°f ,zirconia type I think. It won’t really come into play at idle,but Anywhere down stream will just give you poor performance and mpg and probably that code 43 or whatever o2 code applies. The computer will substitute the non essential inputs using a base fuel map,you still had coolant temp and tps at the time map was missing, probably sucked off idle though. I’m not intimately familiar with actron but as long as it has the 12pin gm obd1 connector it’ll tell you something. They weren’t standardized then meaning not all scan tools gave the same info. I was a little surprised how much more info I got out of the otc on my 93’ compared to a friends older little hand held. I’m guessing archeologists in a couple hundred years are gonna wonder what that little black box with rubber hose is with a 45cal hole through it.
Someday I'll figure this out
7 years 1 month ago #27435 by Rockyroad
That actron 9690 doesn’t look to bad for about $250 on flebay. The only thing you would be missing is the bidirectional to manually actuate things from the tool, but you can certainly get by without it.
  • wacoeagle
7 years 1 month ago #27446 by wacoeagle
I checked the timing with the engine running, the pointer is moving back and forth abt 1/2 inch. I tested the MAP, the signal voltage is all over the place, fluctuating from 0.88 vdc to 2.55 vdc. its fluctuating so fast, you can hardly read the numbers. it has the 5 volt refrence on the other wire, and a good path to ground on the remaining wire. I removed the map sensor to get a good look at it. the backside looks like it has melted sone in the corner. I dont know if this is from an internal problem or if it was heat from the outside near the engine. it sits on a bracket well off of the engine.. im thinking the MAp is the culprit. I would think that the timing moving around is due to the map being bad and the ignition module is just doing what its signaled to do when the map signals it.
Im going to get a new sensor tommorow and see if that fixes it. the sensor should not have a hot melt spot on it, and I dont think the voltage should be fluctuating that fast or that much. probably 5 different values a second. like a confused calculator.
  • wacoeagle
7 years 1 month ago #27448 by wacoeagle
im afraid to swap parts off my other truck because of experiences ive had in my life. heres one example.. I pulled and cleaned A tough old german ladys window A/C. she kept telling me she was worried abt the water.. ad nausium,. finally we got the A/C back into the window, and the exact moment I plugged the A/C in, everything in the house went out.., She started screaming, you ruined my electric, you ruined my vires, you ruined my house!!!! So I went to the breaker box, and nothing was tripped. went in the backyard, to see if meter was running, nothing. so I went in the front to go see if her neighbor had power, when I spotted the big TU Electric truck. they had cut the power to change a transformer.
so I dont want to mess with my other truck and something fail, just as I happened to pull it off, then im out there really sweating it, because that is my fishing truck.
  • wacoeagle
7 years 1 month ago #27449 by wacoeagle
im going to read the online manual for the 9690 and see what all it does. I think in maybe a year or 2 I will have learned enough to be able to use it with good results. im still learning how fuel trims work, and emissions but the big picture is starting to form. Ive learned alot watching danners vids, and a guy called southwest main auto repair, dans brother, and eric the car guy, and yourself, and im appreciative.
If I could find a vid on how exactly the gm computer sequence of operation works, I would get alot out of it. I understand the gm bypass ignition system, its the fuel mapping I would like to know intimately. like what EXACTLY is happening when its surging, is the map reference sensor out of tolerance and the computers sees this and tries to default the fuel trims back to a preset parameter or does it just ingore the errant signal and depend on the coolant temp sensor, and or tps signal.. basically what is going on in the ecm.
7 years 1 month ago #27453 by Rockyroad
Congratulations, I knew you’d find it. I know exactly what you mean on the Murphy’s law and apparently the old German lady did too. I’d also have to pass any thanks on to Paul as well. On the fuel mapping and what the ecm is thinking start at MOATES.NET and poke around and then EFI LIVE. I think you’ll find them interesting.
Also, I’m not positive, but I think the voltage swing max to min should only be about 1.5v on these map’s. If you had something like a mityvac hand pump to apply a steady 19 or 20” of vac, you could remove the variable of fluctuating engine vac. For future reference.
  • wacoeagle
7 years 1 month ago #27454 by wacoeagle
will get a map sensor probably tommorow and pray that fixes it,, the way the signal was jumping gives me great confidence that the map is bad. what is the square black box with the 5 pin connector that mounts right next to the map sensor. it doesnt have anything but a connector plug, no vacuum.
  • wacoeagle
7 years 1 month ago #27455 by wacoeagle
yes I appreciate everyone who contributed. Im going to really enjoy not hearing the truck surge,. Im still teaching my son how to drive standard, so if it is running good, it will be easier. we bought it for 600 and probably put abt 800 in parts in it. probably 60 hours of labor. Im going to give my son the option to buy me out, if he doesnt want it, we will sell it. I hope he keeps it, we spent alot of hours together working on it, and he learned alot. if we do sell it somebodys going to get a good rust free truck, with a lot of new parts. everything works. the only downside is it has no a/c system. were going to put new tires on it soon. the tires will pass inspection but they are worn. headliner is gone. seat is worn, windshield has a chip.. abt
what would be expected for an old truck.
we have replaced battery, ignition switch, radiator, water pump, belt , pulleys, fan, hoses , t stat, brakes and hardware, differential fluid, topped of transfer case fluid, replaced worn sway arm bushings in front, had heads decked and valves worked, complete top end gasket set, new o2 sensor, new tps sensor coming, new cap and rotor, ingnition module replaced and distributor refubished, fuel filter removed and cleaned. new washable air filter. the only thing it needs left to pass inspection is the exhaust pipe needs to be extended to the outside of the bumper. all 4 headlights and tailight lenses were replaced before we got the truck. wish he had replaced the casette player,, haha
7 years 1 month ago #27458 by Rockyroad
He should definitely keep it,a spare vehicle or just don’t want to take that fourth friend with you. His toys are gonna get bigger and need to get them home. That little square 5pin box should be the knock sensor module. I can’t remember exactly what they call it. It sends its info to the computer to aid in the spark timing.
  • wacoeagle
7 years 1 month ago #27463 by wacoeagle
did some research and the map does control fuel and spark, so I see why the ignition is moving around. would also explain the occasional backfire. the engine is a confused mess..... signal jumping around, idle jumping around. if the map controls timing and fuel, I wonder how it interacts with the TPS. THE TPS is also sending a signal voltage to the ECM. Im thinking that once engine is off idle the tps may take over the fuel parameters and the MAP sends signal to the ecm to advance timing thru ignition module.. just a guess. but they both cant be controlling fuel and timing> these years dont have crank or camshaft ref sensors.
  • wacoeagle
7 years 1 month ago - 7 years 1 month ago #27464 by wacoeagle
gonna send jr to the parts house after while. and get a MAP SENSOR. will confirm if it fixes it.
yes he has a little honda civic my bro in law gave him, but every man needs a truck. he could go pick dates up in it. some chicks like old trucks, that raw rumble , smell of burnt oil, they are roomy and manly trucks. that bench seat is good for hugging too. she caint be too fat though, if she is blocking the stick shift, you have to ride around in one gear. My wifes always trying to make excuses to drive my 94.. I tell her she cant handle the silverado,,, too much power. I keep my boat hooked to my 94. If I unhook it and bring it in the front, she will hop in that son of a gone and go. Like its a strong . loud wild horse shes wanting to ride ha it is loud dual exhaust, and puff a plume of smoke on start up, (lworn valve stem seals). love to see people reaction when at gas station and they are behind me, the hear VRROOOO, then the bluish black cloud drifts over thier car,, ha
My 94 runs super, and shifts like dream .
Last edit: 7 years 1 month ago by wacoeagle.
  • wacoeagle
7 years 1 month ago - 7 years 1 month ago #27465 by wacoeagle
I ve heard the 95 1500s are problematic, my transmission mechanic told me they tried to make some changes that year that fell flat. not sure what else they did, with the engines and so on, but many people shy away from the 95 model year.
  • wacoeagle
7 years 1 month ago #27466 by wacoeagle
waiting on jr to bring the MAP sensor from the parts house, went out and took another voltage reading from the signal wire on the MAP, The air is cold and damp here today, the voltage is now fluctuating between 1.66 and almost 3 volts dc. when the voltage gets around 1.55 it is running ok, then the higher the voltage goes the lower the idle to almost shut down. its not a constant, duplicate surge today, its more of a high idle, less prominent surge, but easily heard.
Im thinking that some of the reason for changes in the way the truck runs may be due to when the truck is shut off, the computer resets to a base parameter, and then starts trying to compensate to a happy spot, or in my case compensate for a faulty sensor and incorrect voltage signal .
7 years 1 month ago - 7 years 1 month ago #27469 by Rockyroad
The computer uses the map for baro reading at key on and Wot. So if you’re climbing a mountain and it starts running crappy mash on it or pull over and key off. I would guess the map has priority but the computer is an if this than that device, meaning if I’m seeing this, than do that. Paul’s got a good video on it somewhere. For each voltage of each sensor there’s a programmed injector pulse width. The 95’ was the cross over year for obd2.some came with obd1 connectors some with 2 , but still read as obd1 and monitored more stuff. My 93’ had the electronic 4l60 already but not sure what they made for changes internally if any. I do know my 97’ burb has the newer 4L80e and it did have physical changes in those years. But you can always dummie them up with a carb and external trans controller.
Last edit: 7 years 1 month ago by Rockyroad.
  • wacoeagle
7 years 1 month ago #27471 by wacoeagle
the 8im working on is the 4 speed standard wIth OD . MY 94 has the 4L60E and when it was rebuilt, all of the weak parts were replaced, with improved heavy duty stuff. aluminum instead of plastic pistons, heavy duty OD CAGE, 5 gear pinion sprag , raybestos frictions. rebuilt valve body. new wiring harness. all new electricals , new converter, shift kit. I have a damned good tranny man. he explained to me, that the most important thing is hydraulic pressure integrity. many guy put the super duper red eagle alto frictions and a bunch of other stuff like high performance fluids, additives, ect, but all of that wont do any good if there is a pressure rise malfunction.. the clutches can only clamp as hard as the hydraulics make them, and if the valve body is worn, or the pump or gaskets, the new stuff will not last. He told me he could take a transmission that had worn bands and clutches, and put in a rebuilt pump, new seals and gaskets and valve body, and it would still last a very long time. the valves in the valve bodys can oscillate millions of times in a vehicle with 100.000 miles. when the circuits wear, they leak. same with the check balls, they spin, and can get flat spots in them and leak. the electrical solenoids cycle alot too, they can check good electrically but the pintles can wear and malfunction. Most shops dont rebuild transmissions, they put in the parts they think will fix it and hope for the best. actually rebuilding a transmission is quite extensive. removing and replacing all of the bushings is important too. the guy I have is like a transmission savant. if you met him on the street, you would think he couldnt walk and chew gum, but looks can be decieving. he works out of an old carridge barn from the 1900s , just an old shed, but he is one of the best transmission men in tx. im going to have him do the A500 in my dodge ram im pulling the motor and buying a rebuilt long block for it, . I have 5 trucks. an 89 dodge dakota shelby (only 1500 made), runs but needs trans rebuilt have owned it since 1993, . a 98 dodge ram, bought from my uncle because his floor in his house was rotten, and he didnt have any money to fix it, spun bearing, and transmission worn out has the 6 cylinder good for 300,000 miles if taken care of, )it wasnt)l ,. we did body work and painted it, so its next,, my 94 k1500, and wifes 05 nissan frontier. and of course the 89 scottsdale long bed.
anyway kif u ever go to get a transmission rebuilt, ask them whats the most important aspect of a transmission, if they dont say hydraulic pressure integrity,, RUN..
  • wacoeagle
7 years 1 month ago #27472 by wacoeagle
Map sensor has arrived, gone put it in right na.
  • wacoeagle
7 years 1 month ago #27473 by wacoeagle
whats Pauls you tube name or link,. thanks
  • wacoeagle
7 years 1 month ago - 7 years 1 month ago #27477 by wacoeagle
Ok immediately after replacing the MAP; with a 50 .oo duralast the truck started idling great,, first slightly high idle then down to normal. took truck for a ride and check engine light came on. it threw a code 43. we drove home and took the air filter housing off and I noticed one if the pink wires going to the ignition coil was stretched tight over the EGR valve, possibly pulling on the connector and making a bad connection to the coil, we strapped the wire tight to the fuel line, after pulling some slack so it isnt pulling on the connector anymore. Im going to reset the computer and try starting the truck, it had a bit of a miss while driving and reviing at idle.
This truck has grabbed hold of me like a pit bull on a chihuahua. It simply refuses to leave me alone, like its been neglected so long, and it has somebody who is trying to fix it right, and it has attached itself to me, like a barnacle.
Its like every time I fix something, another issue pops up, like the truck has a gig list its feeding me.
Time to create page: 0.810 seconds
