[FIXED] Looking for a second opinion, in-cylinder capture
  • Tyler's Avatar Topic Author
9 years 11 months ago #3361 by Tyler
Oldsmobile Alero, 3.4L, misfire complaint, audible compression problem during cranking :lol: I take the opportunity to break out the in-cylinder transducer and get a running waveform:
I *think* I'm looking at an intake valve stuck closed. Yeah, it's low compression, but it's also going into deep vacuum in the expansion pocket and the intake stroke. No way we're going into that kind of vacuum with a burned valve or a hole in the piston.
I also see a very gradual slope coming off the exhaust stroke and into the intake stroke. Usually, it's a pretty sharp change in pressure when the intake valve opens, and this is much more gradual.
What say you? Am I on the right track? I'm pulling the valve cover off tomorrow, so we'll find out anyway, but I'm mostly interested to know if you think my interpretation of the waveform is correct. Thanks!
  • Ro-longo
  • Ro-longo's Avatar
  • North Salt Lake, Utah
9 years 11 months ago #3363 by Ro-longo
I wish I had some feedback to offer, I don't get a chance to play with my transducer as much as I would like.
9 years 11 months ago - 9 years 11 months ago #3365 by Noah
I see what you're saying about the massive vacuum, and that certainly supports a stuck closed valve. Just trying to tie the low compression into that..
What is the voltage to pressure conversion?
Curious to see how this one shapes up, keep us posted!
Last edit: 9 years 11 months ago by Noah.
9 years 11 months ago #3366 by matt.white
Replied by matt.white on topic Looking for a second opinion, in-cylinder capture
Don't own a transducer yet so hope I'm not wasting people's time too much but could it be a worn cam lobe or collapsed lifter? Is it feasible the lack of air in is enough to limit the compression pressure that much?
9 years 11 months ago #3372 by Noah
Sounds good to me.
I also don't own a transducer
9 years 11 months ago #3373 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Looking for a second opinion, in-cylinder capture
On a rocker arm engine I have seen a push rod jumped out from the rocker, I have also seen a snapped camshaft.
  • JoesAutoElectric
  • JoesAutoElectric's Avatar
9 years 11 months ago #3379 by JoesAutoElectric
Replied by JoesAutoElectric on topic Looking for a second opinion, in-cylinder capture
I have also seen those engines lose a rocker, but the ones I have seen have made enough noise to let you know something was broke in the cover.
"The man who says it cannot be done should not interrupt the man doing it."
9 years 11 months ago #3383 by Noah
Actually, now that you mention it, I've seen these pull the threads for the rockers right out of the heads.
Saw a guy open his up many times, every time he fixed one, another one would pull out a few months later.
Might have been a 3100, but same thing as the 3400.
  • JoesAutoElectric
9 years 11 months ago #3384 by JoesAutoElectric
Yep, design flaw I suppose, but this may be a great visual of that.
9 years 11 months ago - 9 years 11 months ago #3385 by Tyler
Thanks for all the replies!
Noah wrote: I see what you're saying about the massive vacuum, and that certainly supports a stuck closed valve. Just trying to tie the low compression into that..
Oh crap, my bad! The conversion is 1mV per PSI.
As for the low compression, I'm thinking along the same lines as Matt:
Agreed, I think it's the lack of an intake stroke that's preventing compression. Worn cam lobe or lifter problem is on my mind, but my money is on...
Yep, exactly what I was thinking! I did hear a bit of abnormal noise from the engine at idle, but nothing like the marbles-in-a-tin-can racket you usually get when a stud pulls out. Maybe it's just found a home at the bottom of the valve cover? :lol:
Nice! This reminds me of another Chevrolet that shoved it's pushrod through the rocker arm, stuck valve. Amazing that the pushrod didn't bend :blink:
Sorry guys, I haven't yet had a chance to take this one apart yet :( I'll get to it ASAP and let you know what I find!
Last edit: 9 years 11 months ago by Tyler.
9 years 11 months ago #3386 by matt.white
I love these little discussions.
I have never seen an olds so not familiar with the exact design.
Would it be wise to do a leakdown test before disassembly. If it's low comp but little leakdown then that proves our theory. Obviously if it has huge losses then there's other issues. Just typing that though a leaking cylinder may not be able to pull such a large vacuum though?
9 years 11 months ago - 9 years 11 months ago #3388 by Noah
Right, I should have caught that :blush: . No intake, no air to compress, viola! Low compression.
B)
9 years 11 months ago #3389 by Tyler
matt.white wrote: I love these little discussions.
Ah sorry, I could have been more specific about the vehicle :blush: One of these fine automobiles .
Nice thinking, sir! I actually did do a leakdown test after getting the in-cylinder waveform. Partly to confirm the theory, partly to get more ammunition for pulling the valve cover. Came out at 10-15% leakage.
If it turns out that it is an intake valve problem, then I'll feel more confident in connecting the high vacuum with low cylinder leakage B)
B)
No worries! I honestly didn't know what to make of this waveform at first. I was convinced there had to be a leak, but couldn't explain why the exhaust valve opening was so clearly defined. I'm still a long way off from feeling truly confident with the pressure transducer :blush:
9 years 11 months ago #3395 by matt.white
Don't apologise man. I love a sheltered life on this little convict island. Haha.
So we're all on the same page on this. Rip into it then and report back.
9 years 11 months ago #3402 by Noah
Got some sweet cars on that convict island.
Thinking v8 Ford Falcon. I'd LOVE to own one of those over here!
9 years 11 months ago #3404 by matt.white
Yeah they're ok. They did a turbo 6 which is sweeter. I prefer commodores which is the basis for your camaro from what I understand. Last falcon was made around a month ago. Last commodore next year. No more local production unfortunately.
9 years 11 months ago - 9 years 11 months ago #3406 by Noah
matt.white wrote: Yeah they're ok. They did a turbo 6 which is sweeter. I prefer commodores which is the basis for your camaro from what I understand. Last falcon was made around a month ago. Last commodore next year. No more local production unfortunately.
Chevy had to go continents away to fight the mustang :evil:
The fleet only Chevy Caprice some of the police run here are I believe are also a Holden of some sort
9 years 11 months ago #3407 by matt.white
Yeah forgot them. They're a statesman which is just a lwb commodore. Sorry to go off topic.
9 years 11 months ago #3408 by Noah
Yeah, right. It happens. Wonder what's happening (or not happening) under that valve cover.
9 years 11 months ago #3419 by Tyler
How dare you guys derail my thread! Jerks! ;) :P
Sorry for the delay, but finally tore into this one Friday morning...
drive.google.com/file/d/0BwIz-f3J815JeVl...UVk/view?usp=sharing
Yup, pulled those threads right out :lol: A thread insert and some Loctite later, and it's back to making compression. How long 'till another rocker gives up? Who knows.
Thanks for your thoughts and input, everyone!
Time to create page: 0.485 seconds
