2009 Chrysler Town & Country Touring 4.0L P2100 Throttle Actuator
  • StupidRalph
  • StupidRalph's Avatar Topic Author
8 years 5 months ago #20493 by StupidRalph
WARNING: Auction Vehicle
First off, I'm not a mechanic nor even a DIYer. Just a frustrated car owner who can't find a diagnostician. I apologize for any improper terminology.
Van in constant limp home mode. Started appearing intermittently. At first, I was able to turn vehicle off / on and it would come out of limp mode. Red lightning bolt flashes incessantly. Key dance pulls code P2100. My cheapo code reader doesn't even pull this code.
Throttle body looks new. But since it showed on my mechanics scan tool he recommended a new one. Replaced with new Mopar TB. Error code still persists. Unable to do a TB relearn as his tool wouldn't communicate. He now recommends a new pigtail and possibly pedal. I'm not opposed but I just don't want to pay just swap out working parts w/o proper diagnosis. I do suspect wiring issue. I'd just like to pinpoint which wire and where the open in the circuit occurs. I have already purchased 5183469AB Mopar 6 Way Wiring on Amazon. (Are the wire colors supposed to match my vehicle -- all 6 wires are purple). I'm a bit hesitant in cutting wires willy-nilly I do not think there is a short to ground since I tested for a short using multimeter and test light on negative battery post that did not illuminate. It appears previous owner may have had issue as PCM has possibly been replaced -- June 2016 sticker. Battery is new (12.38v) but has been sitting for a few months.
Below are the actual readings from my multimeter. There is no change in TP Sig 1 as the pedal is depressed.
Pin out
Pin 1 TP Sig 1 - 3.60 volts
Pin 2 5V Ref - 5.00 volts
Pin 3 ETC MTR (+) - No reading
Pin 4 TP Sig 2 - No reading
Pin 5 ETC MTR (-) - No reading
Pin 6 TP Sens Ground - Has continuity grounded to negative battery terminal.
Complete wiring diagram can be found below. I took this snippet from page 66.
cardiagn.com/2009-system-wiring-diagrams-dodge-grand-caravan/
What are the next steps? I'm assuming piercing the wires without any reading at different intervals to see if I get a reading. Currently, I don't have anything to pierce the wire with and my local Lowe's nor Home Depot sold piercing probes. I'm located in Columbia, SC, USA.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 5 months ago #20494 by cheryl hartkorn
first id recheck pin 6 doing a loaded circuit test, the continuity test is not that good. id use a test light atleast hooked to battery positive and see if there is a ground on pin 6. then at very minmum id check pin 4 for an open from the pcm. unhook throttle body and pcm check for an open if you have a good wire then id hook battery positive at one end hook test light up to battery negative see if test light lights. those are the 2 things id start with. do you have any way to read the accelerator pedalpos. sensor inputs??
  • cheryl hartkorn
8 years 5 months ago #20495 by cheryl hartkorn
almost forgot one thing id definetly check is the wiring for the throttle body motor it self. id definetly load test those 2 wires
8 years 5 months ago #20496 by Tyler
I agree with Cheryl, this code is likely related to the two motor circuit wires, pins three and five. I'd focus on those, especially now that it's a hard fault and no longer intermittent.
What you've actually done here is check for a short to power, instead of ground. No worries, that's a worthwhile check! Now I'd suggest doing the same thing, but with the test light connected to B+. Or, with the ohm meter, pins three and five should have no resistance to ground, power or each other.
While you're doing that, have a good look at the female pins inside the throttle connector itself. If any (especially pins three or five) look like they're spread open or otherwise have an abnormally large gap compared to the others, then that's a problem. If you find a pin fitment problem, replacing the connector is an option, but you may also have luck disassembling the connector and retensioning the pin.
  • StupidRalph
8 years 5 months ago #20497 by StupidRalph
Ok. I'm going to digest your suggestions and attempt this now. I think youre saying connect my test light to power and see if grounding it on pin 5 makes it illuminate.
Also, I'm guessing following cable back to PCM. And figuring which cable connects to TB and do some sort of integrity test on it.
@Cheryl
I only have the tools I bought recently to fix this issue.
2 Multimeters
Smart Probe
LED Test Light
Foxtech Scan Tool
Harbor Freight Centech Cable Tracer
  • StupidRalph
8 years 5 months ago #20500 by StupidRalph
Hmm so pin 5 does illuminate the test light when connected to the B+. I can't quite tell if it's the same level of brightness during the daylight.
No discrepancy among spacing on within the female connectors.
I'm still working on the additional suggestions. I can't quite follow the wiring.
  • StupidRalph
8 years 5 months ago #20664 by StupidRalph
Either I'm reading the wiring diagram incorrectly or there is a misprint. I can not correctly trace back the ETC Motor (+). On the diagram the wire goes up and to the left and is dk blu/gray wire numbered 12. On the next relevant page on the left side number 12 wire is now brn / gry and goes to fuse 21 ASD#3. within the TIPM. Any insight?
I am viewing page 66 and 68 listed here.
Page 66
Page 68
8 years 5 months ago #20706 by Tyler
I think you're missing a page? :huh: I dug up the OE diagram on BBB Industries for clarity:
File Attachment:
File Name: tcthrottle.pdf
File Size:350 KB
So pin 5 lights the test light when connected to B+... Is the PCM easily accessible? I'd suggest getting the test light connected up and lit, then disconnect the PCM. If the light goes out, you know that ground is inside the PCM. If the light remains lit, you know that wire is shorted to ground somewhere.
  • StupidRalph
8 years 1 day ago - 8 years 1 day ago #24155 by StupidRalph
Where can I find a chart of the pinout for the PCM? I am signed up on BBB Industries but can not find which connector has the wires for my PCM. I believe its C2 which I'm saying is the second connector from the right. But I'm trying to identify which pin is which. Right now I'm going to try carefully front probe connector and test other end at TB for continuity.
Unable to find on BBB Industries BUT I have identified the different pins on the connector that route to the TB connector. I also found a google image of the same connector pattern and marked the locations. See attached.
Last edit: 8 years 1 day ago by StupidRalph. Reason: Created ad-hoc diagram
  • StupidRalph
8 years 1 day ago - 8 years 1 day ago #24178 by StupidRalph
Unplugged C2 PCM connector and and TB and found ground on 5v ref (pink/yellow) at TB and C2 connector pin 29. As previously suggested by Tyler and Cheryl. Now to find the short.
  • StupidRalph
8 years 1 day ago - 8 years 1 day ago #24179 by StupidRalph
I've attached pictures of my findings.
Pic 1 is most relevant. Pic2 - 4 just show where the wire routes through the vehicle.
Pic 1 shows C2 connector hanging down but also where the cable splices out to a gray connector. When the gray connector is unplugged the short disappears at the TB AND at the C2 connector. It also disappears on the bottom half of the connector. It does appear however on the pink/yellow (5v ref) on the top part of the connector.
Pic 2 shows the above view from the hood of the gray connector and main wiring harness. I've marked them with yellow *s.
Pic 3 shows more top part of connector, and more directional wire routing.
Pic 4 shows routing behind upper intake (?) plenum(?). (told you I wasn't a mechanic :P ) and also the TB connector in the background marked with yellow *.
Last edit: 8 years 1 day ago by StupidRalph. Reason: Forgot the pix
  • StupidRalph
7 years 11 months ago #24217 by StupidRalph
What is my next step? Do I cut open the wiring harness looking for a break in the wiring jacket?
Can my wire tracer (fox and hound) help me?
I don't understand, if its short to ground, shouldn't that pull down the 5v ref. voltage considerably? Its 4.97 at the TB. But there is a 2nd 5v ref on the map sensor also at 4.97.
These two refs may be tied together i can't tell on wiring diagram.
7 years 11 months ago #24218 by Ben
So it appears Tyler is tied up with work again I'll step in while he's gone (not hijacking it from Tyler lol) so let's clarify when you disconnect the grey connected in picture 1 the short to ground goes away on pin 5 of the TB and and the PCM?
7 years 11 months ago #24220 by Tyler
Hijack away! You guys don't need to worry about stepping on my toes. :lol: My new job has a rotating schedule, which is why I'm gone for days then suddenly online all the time.
  • cheryl hartkorn
7 years 11 months ago #24221 by cheryl hartkorn
is your new job still in the mechanic trade??
7 years 11 months ago #24222 by Tyler
Oh yeah, business as usual! Same broken cars and all that, just a weird schedule. :lol:
StupidRalph, what is pin 5 at the TB doing with the PCM disconnected? That's the ETC- circuit, so (hopefully) the short to ground went away when you disconnected the PCM.
Like Cheryl suggested early on, now is the time to load test the ETC+ and - circuits. There's different ways you can do this, but the basic idea is to use the suspect wire in series with an electrical load. The easiest way would be to connect your test light to B+ and probe pin #3 or #5 at the TB (TB disconnected), then ground the corresponding pin at the PCM connector (PCM disconnected). Take care not to spread female pins, of course. The bulb should light brightly. If it doesn't, there's either a problem with your connections, or there's a problem with the wire. ;)
Let us know if you need clarification. :cheer:
  • StupidRalph
7 years 11 months ago #24224 by StupidRalph
Pin 2 is 5v ref at TB and pin 29 on c2 connector at PCM. (I'll add a legend to image). About 8 inches away from C2 connector there is the gray connector which has
The reason i say its shorted to ground is with C2 disconnected from PCM and connector on TB disconnected. My test light, lights green on pin 2 (5V ref) at TB and pin 29(5V ref) on C2 connector. No other pin lights test light nor shows voltage. However, when I unplug that gray connector, my test light does not illuminate on pin 2 at TB nor pin 29 on C2 connector. Nor the bottom part of the gray connector. The top part of the gray connector on 5v ref #1 pin illuminates the light green. It also illuminates on other pins at the gray connector but I havent identified those wires yet. I do know 5V ref #2 is in that gray connector as well.
I can upload a video if necessary.
  • StupidRalph
7 years 11 months ago - 7 years 11 months ago #24225 by StupidRalph
@Tyler
So what is pin 5 on the actual TB doing and not the connector?
I do have an extra pigtail i can plug in to the TB to perform test.
Also, have the TB that came off of the van which also appears to be new.
Last edit: 7 years 11 months ago by StupidRalph.
  • StupidRalph
7 years 11 months ago - 7 years 11 months ago #24226 by StupidRalph
Pin 5 does nothing at TB connector with PCM unplugged.
Pin 5 nor pin 3 illuminate with test light connected to B+ with PCM C2 disconnected.
Pin 2 5V ref in this scenario illuminates green.
7 years 11 months ago #24227 by Ben
Ok slow down with the TB and PCM disconnected your test light does not light on pin 5 of the TB? Pin 5 did light you test light with the pcm connected? We're not to concerned with the 5v ref having ground while not connected to the pcm because there's other sensors still plugged in that could be providing the path to ground when not powered. If the 5vref line is shorted it will not hold 5.0v
Time to create page: 0.450 seconds
