2012 Jeep Liberty Limited 3.7L Not charging new batt/alternator HELP
- gonzalezaamg28
The first thing I did was hook up my snap on solus edge scan tool and run a code scan. I got a bunch of codes in reference to a low voltage from several of the body modules. I then opened up the Mitchell repair manual and followed the prcedures for the DTC P0562. Everything seemed to be okay. I then believed that the PCM was bad because it was not signaling the alternator to engage.
I wanted to be sure before telling the customer to replace a 400 dollar part so I continued to check the wiring. I found something that was odd. The batt sense wire that comes off the back of the alternator is supposed to tell the computer how much voltage the battery has. When a specific voltage is met, the the computer then sends a signal to the alternator to activate it (PWM). When I hooked up my volt meter to battery ground and battery positive I got a reading of 12.5 volts. I then moved my positive lead to the batt sense wire behind the alternator and got a reading of around 9.5 volts. This seemed odd because the battery was fully charged. This reading was with the key on. I then noticed that when I would disconnect the batt negative and reconnect it the voltage would then read 12.5 volts. As soon as I would turn the key forward, the PCM it would then read the 9.5. There was clearly some type of voltage drop. I started to check the PCM connector where the batt sense is connected to and the other wires on the connector. I found that the can bus (-) and can bus (+) had continuity with each other. I also noticed that the shielding was browned as if they were or had gotten hot. No fuses are burned on the vehicle. and the vehicle turns on fine. I tried tracing these 2 wires down, but had no luck. IM STUCK ANY IDEAS? Am I doing something wrong?
- gonzalezaamg28
- bruce.oliver
- Thank you received: 88
I think I have a good article on Chrysler charging systems on my computer at work. I will post it up tomorrow
- gonzalezaamg28
- gonzalezaamg28
- gonzalezaamg28
- gonzalezaamg28
- bruce.oliver
- bruce.oliver
Yes that can be normal. What is the actual ohm reading? Are you checking at the DLC? Chryslers are different from a lot of cars, the CAN circuit to theDLC is a separate circuit from the com wires between modules. The car starts and runs, if there was a problem with the CAN wires it would set codes and/or not communicate with your scantoolgonzalezaamg28 wrote: and thank you so much for the response Bruce Oliver I really need as much help as I can get. BTW what do you thing about those CAN BUS wires? is it normal for them to have continuity?
- bruce.oliver
www.remyautomotive.com/resource/Technical-Bulletins
- gonzalezaamg28
- gonzalezaamg28
- gonzalezaamg28
- cheryl hartkorn
- Thank you received: 130
- gonzalezaamg28
- gonzalezaamg28
- gonzalezaamg28
Bruce - Love that Remy page that you posted! :woohoo: I'm adding that to the service info sticky.
- gonzalezaamg28
- bruce.oliver
There is some great info in their bulletins.Tyler wrote: Nice fix.
Is there any suspicion that the first alternator may have damaged the PCM?
