07 bmw lean codes and runs rough
- Jay2034
- derekoliveira
- Jay2034
- derekoliveira
I had a similar problem on a Passat 1.8 GLI!!!
- Jay2034
- Dave101
- Show me what it's not!!
- Thank you received: 7
I think he means, while watching scan data (lean/rich fuel trims) tap on the MAF and see if the fuel trims start coming back to normal. If so, need to clean the MAF, check the wiring or clean the MAF. Hope this helps.Jay2034 wrote: Thank u brother but What do u mean maf good idle tap?
- derekoliveira
So when is running ok, if you tap the MAF and it get bad idling again it means the culprit is MAF!!!
- Dave101
Looking at your scan data, when both banks are running lean (running bad) tap on the MAF and look at your codes (also the car may start running better). If they start to return to normal, then it's probably the MAF.derekoliveira wrote: The car is running good when you start and then cames the problem, isn t?
That is certainly a good test to do. You can also inspect the MAF to see how dirty it is. I'm not sure that your problem is going to be the MAF however. It sounds like you have a huge vacuum leak somewhere. Have you checked to see how much fuel pressure you have? I've had that bite me a few time as well.
- Tutti57
- Thank you received: 253
- Jay2034
- Jay2034
- derekoliveira
- Jay2034
- Jay2034
- derekoliveira
- Tutti57
Wot while watching up stream o2 is a way to see if it's getting enough fuel, if voltage goes high, indicating a rich condition (what you want at wot).
- Jay2034
