Question on a coil waveform!
  • Rukerin
  • Rukerin's Avatar Topic Author
10 years 1 month ago - 10 years 1 month ago #1304 by Rukerin
Question on a coil waveform! was created by Rukerin
I had this 2005 Chevy Silverado 4.3 engine had a no start problem . I checked on the coil primary circuit signal and got a waveform , then i found the signal wire was open so i fixed it . But after the repair the signal waveform changed! I remember that it had something to do with the coil making a magnetic field or something similar . Am I correct or does the computer change the signal after knowing it had good connection? Does it apply on all engine coils?
Will post them waveforms . If someone could explain , in advance thanks!
This is with broken wire.
This after the fix.
Last edit: 10 years 1 month ago by Rukerin.
10 years 1 month ago #1308 by Tyler
Replied by Tyler on topic Question on a coil waveform!
Hey Rukerin!
Just for my info, was the truck running during your second capture? No offense meant here, but it looks like your scope didn't have a good ground at that time. The sharp positive and negative spikes followed by a curve are somewhat characteristic of that, seen it many times on my own scope.
It might help me to answer your questions if I knew where exactly you were during these captures. Here's a diagram for reference:
Were you scoping the white/black wire between the ignition coil and the ICM, or were you scoping the white wire from the ICM to the PCM? Not trying to be picky, just want to make sure I'm on the same page.
  • Rukerin
10 years 1 month ago #1310 by Rukerin
Replied by Rukerin on topic Question on a coil waveform!
I was backprobing on ICM connector "D" wire on you're picture. And forgot to mention it was cranking only on both pictures , and after I fixed it i connected a test light from coil post to ground. I remember that coil could be damaged if the spark had nowhere to go. And for ground had a jumper wire directly to battery negative post.
10 years 1 month ago #1316 by Tyler
Rukerin wrote: I was backprobing on ICM connector "D" wire on you're picture. And forgot to mention it was cranking only on both pictures , and after I fixed it i connected a test light from coil post to ground. I remember that coil could be damaged if the spark had nowhere to go. And for ground had a jumper wire directly to battery negative post.
Ooooooh, OK then, I take it back! The after waveform somewhat makes sense now, knowing that the spark is shorted out. You're completely right, 'deadheading' the coil secondary output can do damage. Good move by giving the spark an outlet.
That 'taper' off after a spike also happens when the spark is shorted. Here's an example of a failed COP primary control waveform on a Jeep Compass:
The taper is there because the energy is getting bled to ground, instead of going across an air gap and creating a burn line in the waveform.
  • Rukerin
10 years 1 month ago #1325 by Rukerin
Thanks for the info Tyler ! And sorry for all the questions , noobie here :) but I was triyng to find out if the change of the waveform was caused by the ignition coil magnetic field and all that stuff or you think the change was made by the computer knowing it had a good connection? What im trying to learn is if some other day I get a no spark Chevy with a bad coil and connect into that wire would I see something similar to the first image or the second one?
10 years 1 month ago #1330 by Tyler
Rukerin wrote: Thanks for the info Tyler ! And sorry for all the questions , noobie here :) but I was triyng to find out if the change of the waveform was caused by the ignition coil magnetic field and all that stuff or you think the change was made by the computer knowing it had a good connection? What im trying to learn is if some other day I get a no spark Chevy with a bad coil and connect into that wire would I see something similar to the first image or the second one?
No worries, ask away!
I believe the change in waveform has to do with the coil now building/collapsing a magnetic field, since you probably restored current flow through the coil with your wiring repair. You mentioned finding an open wire, where was it exactly? Your 'before' waveform suggests that it wasn't a complete open, necessarily, but high resistance in the white/black wire between the coil and the ICM.
What you'd see in the case of a failed coil would depend on how the coil failed, exactly. An open or high resistance in the primary would look more like the first waveform. If you're a subscriber, there was a newer Premium video on a Nissan with a shorted secondary, great video:
For reference, with everything working correctly, the waveform should look something like this:
  • Rukerin
10 years 1 month ago #1332 by Rukerin
Ok thanks!!! So you suggest that if I cut the wire completely I would have seen a flat line ? And yes you are correct the wire was not all the way cut I'll post a picture of it tomorrow . It was kind of internal damage because you could not see it. The strange things is it did not have continuity with the volt meter but I'm sad I did not ohm the wire maybe I can still do it with the connector! I'll see what I find out tomorrow.
10 years 1 month ago #1356 by Tyler
Rukerin wrote: Ok thanks!!! So you suggest that if I cut the wire completely I would have seen a flat line ? And yes you are correct the wire was not all the way cut I'll post a picture of it tomorrow . It was kind of internal damage because you could not see it. The strange things is it did not have continuity with the volt meter but I'm sad I did not ohm the wire maybe I can still do it with the connector! I'll see what I find out tomorrow.
Correct, if you cut the wire you'd end up with zero activity on that circuit. Really, that's pretty much what you had in the first capture, but apparently there was some kind of connection in there, 'cause you can see around 1V available when the coil driver is off. Great find, by the way! B)
The following user(s) said Thank You: Rukerin
  • Rukerin
10 years 1 month ago #1364 by Rukerin
Here is the wire I found to be bad!
One last question , should I post questions here about waveforms? Or somewhere else? I still have a ton of questions about waveforms and I will be getting a lot more of them at work! Thanks a lot!
10 years 1 month ago - 10 years 1 month ago #1376 by Tyler
Ahhh, right at the connector, nice. Did you end up repinning that connector?
Totally keep the waveform questions coming! We're happy to answer, and chances are good that someone else will benefit from reading the discussion, too.
Where to post them? Good question, 'cause it could make just as much sense to post them in the Diagnostic Tools section. I'd say if it's related to a vehicle you're trying to repair, post it here. Otherwise, the Diagnostic section.
Last edit: 10 years 1 month ago by Tyler.
  • Rukerin
10 years 1 month ago #1377 by Rukerin
I bought a new connector for the repair . I have another one :) , would you suggest using current ramp or voltage waveform when checking primary ignition? Thinking in having the most detail or info on what's happening.
10 years 1 month ago - 10 years 1 month ago #1386 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Question on a coil waveform!
The way I see it is the more waveforms people show and ask about the more we all benefit.
Primary current and primary voltage waveforms really show different but related things, which to go for first is really a matter of how easy it is to get access and what equipment is available.
Primary current is often the quick and easy to do and you can often look at more than one cylinder at a time, it is a 100% surefire way to spot a shorted primary or a failure of the control pulse, but won't tell you anything about the secondary HT spark.
Primary voltage is really a sneaky way of looking at secondary HT voltage, it will tell you if an HT spark is happening and its durration although it will not always tell you if the spark is occurring in the cylinder.
Looking directly at the secondary voltage used to be the go-to method but these days it is rare to find an engine you can clip a capacitive HT probe directly over the plug lead.
COP probes tend to be a bit hit or miss and the wave forms they produce tend to vary greatly, but they are quick and easy and sometimes the only method possible.
When I suspect a coil has a secondary HT fault I generally stress test the coil to see if it will produce at least a 25mm (1") spark, about 25kV working on the rough rule of thumb that every 1mm = 1kV
Last edit: 10 years 1 month ago by Andy.MacFadyen.
  • Rukerin
10 years 1 month ago #1387 by Rukerin
Thanks Andy! I think I have one of those capacitive probe for secondary , but really could never get to understand the waveform i always thought the clip did not work correctly, you guys would be up to help me understand it if I post one o them waveforms ?
Time to create page: 0.325 seconds
