2007 srt8 no start rpm signal
- Topend
Have a 2007 srt8 jeep I did an engine rebuild on just rings bearings and crank cut and heads redone.
will not sync crank signal and watching it on scanners it goes to 142 rpm and drops off and will sometimes flicker again but not enough to start.
sensor has 5v and ground and signal back to pcm connection does what it should with a dvm.
I do not have a scope right now and will buy one if needed, but I don't see anything wrong with crank ring and did try 2 other sensors 1 factory and same luck.
is there anything that would shut the signal off at pcm?
all grounds even per manual are good and I even used cables for some extra.
Thanks in advance, it did run before was rebuilt just spun a bearing and now im struggling.
- Topend
- Topend
And turning by hand I got nice signal cutoff with a dvm also
- juergen.scholl
- Active partschanger
- Thank you received: 462
If it was a complaint about "sync" you may want to look at the cmp(s) as well.
Is spark and/or injector pulse present? I am sure you verified the physical timing....
- Topend
I did check cam sensor and wiring and even tried another jic but came up same.
I did not check injector pulse but when I did compression plugs where wet with fuel before i disabled fuel pressure to test.
- Topend
- juergen.scholl
Can you get your hands on a graphing scantool?
Verify that you get injection pulse indeed. Again, do you have spark? (Spark/injection would verify the pcm recognizes a valid rpm signal.)
Make sure there is no immobilizer issue present.
- Topend
- Topend
- juergen.scholl
- Thank you received: 1138
- Topend
I actually got out of most the automotive and went to heavy truck I build a lot of caterpillar engines, specialize in mechanical but I said to myself this thing really slings the oil. Lol
- Topend
I have a laptop with a nexiq, I do mostly big diesel stuff now and sold my modis way back.
This kind of problem honestly is out of my norm I'm more mechanical or actual power and ground.
But I did this job to help a good friend and I'm sinking on it.
- juergen.scholl
The scan data rpm dropping to zero while cranking is not normal in my opinion, but without seeing the signal generated by the CKP, it's difficult to tell why that is happening.
If you don't plan on jumping into the diag game with both feet, it might be more cost effective to hire this one out to a mobile specialist than to buy a scope kit and learn how to use it for this one problem. Of course, of you do want to spend money and time to learn scope use, then this is a good place to start.
- Topend
I found one local and it was 600 i offered 350 and am likely to pick it up on Tuesday.
Sadly it was a spouses that passed and she had a mechanic check it out and he said it works and is there but did not know the software off hand.
Does this sound sensible on this?
I only ask because it's not my specialty but have always learned learning it best to usually go with the most support vs best
There is an entire section on Scanner Danner Premium dedicated to training on that very tool, so I would say from that standpoint you are in a good position to learn while using it.
- Topend
It seems it only goes to 2003 but here are pics of what I got I had to clean it was deff dusty so case is drying.
Would I be able to use the 2003 ram 5.7 to check this before updating and what's the best way to update this? Thank you
- Topend
- Topend
