[FIXED] 02 GM 3.1 403-5 DTCs
- StepSide88
Current DTCs
P0403,
P0404
P0405
pending P0404
the Campbells soup version
Parts Swapper here... at least it feels that way.
New to New OBD ii my prior experience has been learning EFI for a 88 Toyota.
DVOM stuff.
Hoping to save my friend a few $$$ befor a planned trip this summer I wanted to do a tune up on her car.
I started out changing the spark plugs, wires, air filters and an oil change.
It went from poorly running couldn't find WOT because it fell on it face before it hit third gear and needed an egg under the pedal... to a no start.
I finally found a loose connection to the ICM but not before becoming the PS of lore
Along the way I did get an OBDII scanner from some nameless entity and then one for my laptop from CHINA to book. Cheaper AND BETTER...
Originally I saw a random miss fire code and a couple others I failed to log before I hit that stupid button.
My cousin directed me to 'the box' and also here after I hit the stupid button.
I now know all is not lost but some of it may well return.
After wiping the codes and eventually getting the thing to fire I was able to take it for a test drive.
As bad if not worse but over the course of a dozen or more 0-40mph cycles ran good enough to hazzard a shot at highway speeds.
Next did a GM cold start reboot drive cycle and things eventually reached original drivability... i.e. it was gutless.
Back home, key off back on DTCs P0403, P0404, P0405 are shown.
While looking up P0403 I find the How to test for restricted exhaust (catalytic converter).
First thing this AM I'm at AZ to rent a tester. Nope. They can order one
O'Reilly and 2 NAPAs same story.
Deep in the comments section were some alternative tests I could preform in the mean time.
Other test methods:
1. use vacuum gauge (0,65 bar): § WOT : zero vacuum.
§ If restricted: 2000 RPM -> vacuum drops more and more
2. infrared thermometer test on cat (@ 2000 RPM, outlet 60° hotter than inlet)
3. scantool: 2nd O2-sensor steady voltage (±0,5V)
Hooking my Vac to the brake booster line and watching for gradual vac loss while @ 2500rpm it didn't happen.
No Vac loss.
At the same time watching the 02 V signals 02#2 varied +or- .4v from 0.5v
I wasn't ready to put it up on jacks to take the cats temp. at that moment, but surely can.
I'm looking for direction, suggestions or ideas and in the I'm going to go ahead and start looking at making my own Exhaust pressure tester.
thanks
- Thank you received: 1138
No harm, no foul.
I'm late for work or I'd search out a video for you.
Look on the Scanner Danner YouTube page for a wide open throttle O2 test.
Your symptoms make me feel like you could be looking at a fuel delivery issue, and this test will help point us in the right direction.
Basically from a stop, do a wide open throttle pull through first gear while watching the upstream 02 sensor data.
If the fuel system is good and the mass airflow sensor is operating correctly, the upstream 02 should be rich the whole time you're at WOT (wide open throttle)
- Ben
- Thank you received: 215
Take a picture of the WOT run if you can, and post it here.
A backpressure tester would be cool, but you can also do the same check at the EGR valve itself. Remove the valve, plug the port that goes to the intake (as it'll have full manifold vacuum with the engine running), and jam your vacuum gauge into the exhaust port. If needed, run the engine to find out which is which.
Check the pressure at idle and 2500 RPM just like in the video. Don't worry about the limited scale on the vacuum gauge - if any of your readings max the gauge, then you've already found the problem.
- StepSide88
RE Fuel Pressure. Not supported so I hooked up the gauge and watched through the windshield.
50-55psi the whole time.
This photo is the data as it read on the 'dashboard' of the scanner.
I could also post the Strip Chart view but this view shows the most data in one shot.
On 100% throttle it bogs bad
@25% it accelerates fairly smooth up to 30mph.
To be honest I'm not sure I fully grasp which reading of the STFT indicates rich or lean.
I'm going to guess Higher O2 readings indicate leaner fuel ratio?
I am much more inclined to do the EGR exhaust pressure test than the up stream O2. I had to pull the EGR to make enough room to get down there anyway!
I'm going to wait until I see the feedback from this post
- Ben
Very good data here, BTW. This is exactly what we needed. The low Load and low MAF readings are an indication of poor engine breathing. The upstream O2 is showing close to 1V (rich), which means the cause of the low power is not likely to be related to lack of fuel. Your fuel pressure reading tends to back this up.
The short term and long term trims aren't valid during this WOT test, as the PCM goes into open loop and stops trying to 'trim' fuel. Once you go back to just cruising along, closed loop will probably kick in, and the trims will start moving again.
Sweet! :lol: I'd say do that test next, as your WOT data is suggesting a plugged cat. A restricted intake is also a possibility, but less likely. If your backpressure test comes back negative, then let us know and we can suggest further testing.
- StepSide88
stft 0% -
ltft 6.25%
Mass AF 6.21lb/min
GM- Cause
Engine runtime over 90 seconds at idle speed, ECT sensor input more than 132°F, fuel adjustment more than a calibrated amount in the PCM, then the PCM detected multiple misfires had occurred
Above 50% throttle for the most part.
- StepSide88
MAF @ 894rpm 1 lb/min @99 sec. ---- 0.9 lb/min @ 128 sec
Load 4-5
MAF @ 3893 rpm 7.4 lb/min ---- load 44 approx. = WOT
- StepSide88
So I hope to run the Exhaust pressure test tomorrow.
- StepSide88
Tyler wrote: Thanks for the update! Just curious, what program are you using for the scanner?.
OBDWiz is the software. $32 for the connector includes the key to download the software and for another $40 or so you can upgrade to their 'pro' package which includes the ability to graph, run the EVAP test and stuff.
It took a while to sort out the capabilities and how to select gauges and such but in the end.... its just more software to figure out.
- StepSide88
- Ben
Lol any excuse is good enough to fire up the lathe !StepSide88 wrote: No adapters for my gauge so I went for something that let me mess with my lathes... that way I'm not thinking all I do is work on the car.
Sounds good to me! :lol: Wonder if anyone produces an adapter like that… If not, market it.
- StepSide88
The adapter works with the exception of the phenolic plate (piece of scrap) I used as a backer for the rubber intake gasket.
It lets you know when you hit 3K rpm. Still I messed with the lathe and played with all my toys (scrap and spare junk from garage sales or just junk)
which was worth it if it clears a part from the 'to buy' list.
At best it maybe drew 2 lbs.
- StepSide88
P0403
P0405
no P0404
I thought I"d posted this but don't see it so more info
EGR connector pins read:
A B C D E
KOff 7.8v 7.1v 7.5v 5.01v 12.8v
KOnEO 34.9v 34.9v 34.9v 5.01v 12.8v
KOER 3.7-7v vari +/- vari .961v 4.9v 2.9v - 7.9v vari
SO after close but not exact Drive Cycle and waiting for the 45 min
I No longer have
P0403 or P0405.
I do have P0404 back however.
All On Board Monitors now Pass
But Monitor Status shows the tests for Catalyst, EVAP, O2 sensor heater, and EGR sys are incomplete.
17hrs to next Key On.
So while I drift down this slow section of the river any suggestions?
StepSide88 wrote: OK I have a result.
Wow, highest reading was 2 lbs? What was the measurement at idle and 2500, specifically? I don't doubt your readings, just want to make sure I understand what you saw.
- StepSide88
the needle moved between .5lbs idle and 2lbs or maybe slightly more at WOT as best I could read while driving with the gauge laying outside against the windshield on the pass. side.
What sort of MAF readings are the normal range for this beast?
