2001 Dodge Dakota 5.9 Automatic 4x4--Bank 2 sensor 2 slow response.
- GTaylor
Measuring the voltage with a multimeter on high current circuit such as a sensor heater won't pull the voltage down by any noticeable amount . Reasonable quality Multimeters (and Oscilloscopes) have very high input resistance on the voltage scale. However some voltage probe type tools have a lower input ressistance (300 k ohms) with can pull the voltage down on sensor outputs but are still OK for high current circuits such as O2 sensor heaters and lights.
- GTaylor
The 3V bias makes me think of a resistive short. I can recall running into a similar issue when water got accidentally sprayed into the harness side of the O2 connector. It wasn't a dead short, but it was shorted enough to pull the bias down and take the O2 signal with it. Possible weak/missing weatherpack seal?
Ohming wires sucks, but this might be a good occasion. PCM and O2 disconnected, see if there's a reading to ground. You can also try cutting the O2 signal wire close to the PCM (where it'll be repairable, of course) and see if the bias goes to normal.
- GTaylor
- GTaylor
- Ben
- Thank you received: 215
- GTaylor
- GTaylor
Ben wrote: Don't mean to cut in here but could the pins be in the wrong place in the 2-2 connector? Or possibly the wrong sensor ? Is this a 3 or 4 wire sensor?
Exactly my thoughts.
You could also try swapping downstream sensors bank to bank. Don't even install them, just hook the B1 sensor to the B2 connector, see if it still behaves the same way.
- Ben
- GTaylor
- GTaylor
GTaylor wrote: I've done that. Have a spare new sensor also. When I started they had the sensor connectors swapped side-to-side. 02-2 goes wonky soon as a sensor is plugged in. I have the connector view now but can't seem to upload it.
Email it to me? wrenchturnsyou@gmail.com
You're thinking the heater pins are swapped? I'm not sure that'd cause this issue or not...
- GTaylor
- Ben
GTaylor wrote: NO. Clearly stated above 1&2 are heater. I do NOT have a heater code or issue. i have a SENSOR code. I have 4.88-4.96V at ALL four sensors when unplugged. Can connect all except 02-2 w/o change in bias. When 02-2 is plugged in voltage gets pulled down on that sensor. Since it starts at a lower voltage, when heater warms it up, voltage drops to zero, which codes.
I gotcha, just misread your post.
- GTaylor
- GTaylor
- Ben
