1991 Honda CRX start issue
- Jwilusz
- Thank you received: 2
Now I'm guessing if I unplug injector 3 and the wire goes to 5v then it's an injector if it does not then it's the wire. I also think there's more at play here considering the rest are way over 5v. I'm told fix the one and the rest get in line but I don't believe that one bit.
- Thank you received: 1139
- Jwilusz
You're going to need 12v for these injectors to work
I understand that. I'm trying to see if my logic is sound in the sense that if I unplug the injector and still don't get battery voltage on the wire then the wire itself is shorted out somewhere? I also need to figure out why injector 1 doesn't read battery voltage as well.
Where as you are measuring 5v-9v, I think it more likely you are dealing with a voltage drop. A poor connection or high resistance somewhere between the injector harness and whatever feeds it power (fuse box, main relay, ignition switch). You'll need a diagram or some kind of service info to find the source.
- Jwilusz
If you unplug an injector and don't see battery voltage on the power wire, you could have a short, but this would likely result in a blown fuse, and 0v on the wire. (Short meaning copper wire touching ground)
So 5v reference signal doesn't exist with these cars? Key on II. I should see battery voltage on the wires the injector wires to ECU? That's what I'm trying to make sure is that the ECU is getting signal from the injectors. I still have a crank no start after going through and finding I needed a dizzy. Now I believe it might be fuel related even though when trying to start I can smell the fuel.
So, in it's un-energized state, the injector will have battery voltage on both wires (with the injector connected) going all the way back to the PCM.
To verify the circuit isn't open or shorted you can simply check for battery voltage at the injector control circuits at the PCM connector.
From the test you describe, the injectors don't have the proper supply voltage, so this test is unnecessary at this point until you restore battery voltage to the feed side of the injectors in my opinion.
- Jwilusz
The injector is fed battery voltage on one wire and it is controlled by the PCM supplying ground on the other wire.
When you say PCM are you referring to the ECU?
- Jwilusz
Attachment not found
Not sure what this is but I don't really want to download something like this.
- Jwilusz
I edited my previous post and added an explanation to it.
Wire color is proper. I wanted to rule out a short in light blue wire for injector three. Ran a test with multimeter and got a beep. Wire must be good. So now if I read your post right I should check to ensure the main relay is getting 12v at blue/white and also yellow/black. I have checked every ground wire involving ECU. When I touch my multimeter to the green/black and touch the other lead to a known ground I get a beep.
I know you said it was a B series swap, but a concrete year/make/model of the donor car would go a long way.
- Jwilusz
What is the engine and computer combo in the car?
Engine is a B20 with a B16 head. They are OBD 1 and I have an OBD1 ECU with OBD 1 alternator and Dizzy. The ECU came from a running drive b swap that was just like mine from a 91 Honda Civic. The engine harness is professionally built from Monotech.
But I should have responded in kind, sorry for the confusion.
- Jwilusz
Ignition switch plug under the dash
Blue/White 12V
at the main relay these readings were taken with red probe going into the main relay and black probe on the closet body ground
Position 1 is a yellow wire 12V
position 3 Yellow/Black and 2 wires are going into this 12V
Position 5 Black/Yellow and 2 wires are going into this 12V
Position 7 Yellow/Black no voltage
Position 2 black no voltage
Position 4 Blue/white and 2 wires are going into this 0V
Position 8 green/black and 2 wires are going into this 0V
Fuse number 2 shows 0V inspected fuse and it is in good condition
here's where things get interesting and I will try to explain it the best I can after cycling the key again I got the below
red probe in Blue/white wire at the main relay
black probe in Green/black at the main relay
reading -12.51V
Green/Black to body ground 12V
This seems to tell me that the Green/Black might be having an issue? Green/black is supposed to be grounds and should not have voltage and the Blue/White should have power at the main relay. Where would you guys go from here? Trace green/black and see if I can find where both wires go and test them for resistance end to end or test resistance on Blue/white?
- Jwilusz
- Jwilusz
I also want to point out that your diagram doesn't have trh same color injector wires (if I am reading it right). Looks like red, red, yellow, yellow?
- Jwilusz
- Jwilusz
- Jwilusz
I can't get a diagram for your car. The missing feeds to these injectors should not cause the car not to start. Is the engine flooded by any chance? Do we have fuel, Spark, compression, and even Timing? Have you tried an alternative Fuel Source?
The engine swap.makes it hard to get a diagram. Code 6 causes hard cold starts. I'm changing that sensor today and will see what happens from there.
- Jwilusz
