ASE Test question
  • Ro-longo
  • Ro-longo's Avatar Topic Author
  • North Salt Lake, Utah
9 years 10 months ago #4432 by Ro-longo
ASE Test question was created by Ro-longo
Earlier this month I took my A6 (Electrical) recertification test. This one question has been stuck in my head for the past couple of weeks and I wanted to get some other opinions on how you would have answered this. So here is the question and a couple of options for answers that were available (it was a multiple choice, 2 of them were obviously incorrect)
After charging a vehicles battery a Technician notices the electric cooling fan runs constantly. What is the most likely cause.
A: A short to ground at point A
B: A short to power at point B
9 years 10 months ago #4440 by Tyler
Replied by Tyler on topic ASE Test question
Yeah, I see why this one would stick with you... OK, I'll take a shot.
A short to ground a point A is definitely possible, but why would it happen after changing the battery?
A short to power at point B would also cause the fan to run constantly, but why would that be any more likely than answer A? :huh:
Where's answer C? Where the BCM got 'logic locked' by the low battery voltage? That's WAY more likely than A or B, IMO.
  • Ro-longo
9 years 10 months ago #4450 by Ro-longo
Replied by Ro-longo on topic ASE Test question
Tyler wrote: Yeah, I see why this one would stick with you... OK, I'll take a shot.
It was after charging the battery
I can't remember off the top of my head exactly what the other 2 choices were but they could be eliminated easily. (opens) All the choices had to do with reading the wiring diagram.
9 years 10 months ago #4453 by Noah
Replied by Noah on topic ASE Test question
I'm saying A. My reasoning being the battery was discharged because the fan was running continuously. Presumably with the key off, that takes the BCM out of the picture for me.
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
9 years 10 months ago #4458 by ScannerDanner
Replied by ScannerDanner on topic ASE Test question
Noah wrote: I'm saying A. My reasoning being the battery was discharged because the fan was running continuously. Presumably with the key off, that takes the BCM out of the picture for me.
I agree with Noah unless the BCM has an after run program designed into the fan :unsure:
Don't be a parts changer!
  • ScannerDanner
  • Administrator
  • Administrator
9 years 10 months ago #4459 by ScannerDanner
Never mind. A short to power at point B is after the BCM so it doesn't matter what the BCM is doing.
Sorry Noah, I no longer agree :P
They are both good answers, not sure how you would pick the best one.
9 years 10 months ago #4464 by Noah
ScannerDanner wrote: Never mind. A short to power at point B is after the BCM so it doesn't matter what the BCM is doing.
Ahhh yes, good point.
I suppose it comes down to the internal construction of the fan module. More specifically, the transistor. You would think it's ground is constant, considering the module has constant power and ground.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 10 months ago #4469 by Dylan
Replied by Dylan on topic ASE Test question
:huh: :huh: Not familiar with these ASE tests, but they seem like a lot of fun :whistle:
You should go back to school Paul :P :lol:
9 years 10 months ago #4475 by rccharlton
Replied by rccharlton on topic ASE Test question
I would say B. because it is a fan Module. If the battery was low the model might not turn the fan on if B was grounded. If A was grounded the fan would run until it drained the battery down to almost 0v's.
  • Ro-longo
9 years 10 months ago #4517 by Ro-longo
When I took the test I chose option A after flip flopping on the answer. I was trying to figure out the "most likely" option. I think I stared at this question for about 5 minutes. I guess I will never know what the answer ASE was looking for, since ASE doesn't let you know what the correct answers are.
I swear the people that make these questions up like to screw with us. :S
9 years 10 months ago #4540 by Tyler
Ro-longo wrote: When I took the test I chose option A after flip flopping on the answer. I was trying to figure out the "most likely" option. I think I stared at this question for about 5 minutes. I guess I will never know what the answer ASE was looking for, since ASE doesn't let you know what the correct answers are.
Something tells me this one was one of those 'experimental' questions that aren't graded. Truly frustrating, not knowing the correct answer :(
  • Ro-longo
9 years 10 months ago #4582 by Ro-longo
This was a recertification test, I didn't know they had those for that type. All of them were scored.
9 years 9 months ago #4736 by bruce.oliver
Replied by bruce.oliver on topic ASE Test question
I've got a couple questions. First what does it matter what the most likely cause is?
Second, does this even happen? If so how do you fix it?
9 years 9 months ago - 9 years 9 months ago #4739 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic ASE Test question
My first instinct a a hammer and spanner guy was A but I was unsure so I revised my transistor theory and I am now more sure it is A.
Link to www.technologystudent.com/
However I can think of other reasons why the fan should run continuosly.
Last edit: 9 years 9 months ago by Andy.MacFadyen.
9 years 9 months ago #5100 by Tyler
Went to take my own A6 recert test, just so happened to see this exact same question! Skipped right past the part where I agonize and second guess myself, went directly to answer A, didn't look back. :lol:
9 years 9 months ago #5195 by bruce.oliver
Took 4 tests this morning. My first time so not a recertification test. I saw this question to. I didn't miss any scored questions on the electrical test but don't know if I got this one right since it could've been a research question
9 years 9 months ago #5197 by Tyler
bruce.oliver wrote: Took 4 tests this morning. My first time so not a recertification test. I saw this question to. I didn't miss any scored questions on the electrical test but don't know if I got this one right since it could've been a research question
That's what I'm thinking. Congrats on getting 100%, though!
9 years 9 months ago #5205 by Noah
Seriously, well done! B)
9 years 9 months ago #5207 by bruce.oliver
Thanks. I missed 2 each on suspension and brakes then missed 3 on engine performance
9 years 9 months ago #5209 by Noah
bruce.oliver wrote: Thanks. I missed 2 each on suspension and brakes then missed 3 on engine performance
That's really good. I only took the electrical and the engine performance tests and got 100% on each. That's another reason (excuse) I've been putting off the L1. Set the bar too high :sick:
Time to create page: 0.371 seconds
