P0300, Low Power
Waveform file:
drive.google.com/file/d/12Y7VYvpTr_QGi55...Gl_/view?usp=sharing
eScope software:
drive.google.com/file/d/1DPm_OMXMyU0jKtd...YEV/view?usp=sharing
I guess the decompression pocket is a little deeper than the intake... IVO seems a little late... Jumped timing chain?
Tyler wrote: Jumped timing chain?
That's a good guess.
Tyler wrote: Wow, no preamble or anything! :silly: So I have to make a call based on this waveform alone?
I gave you the cam position markers....geez. :dry:
:lol:
Chad wrote: That's a good guess.
How do we prove it? What would you like to see, next?
This is brutal. But hey, at least you gave us the Y/M/M/E! :silly:
VVT PIDs might be fun? But probably not necessary. If the intake were truly that late, there'd be more than just a P0300. Plus I rarely see this engine jump time.
Late IVO can also be caused by a wiped cam lobe or smoked cam follower. I see that a lot more often. :lol: Intake pulse waveform, please.
- Matt T
- Thank you received: 276
Chad wrote: What would you like to see, next?
Pics with the timing cover removed :lol:
Or 'scoping CKP and CMPs would be a less invasive option if you can find a known good.
- Matt T
Tyler wrote: Late IVO can also be caused by a wiped cam lobe or smoked cam follower.
Would that cause the deeper decompression pocket? I'm thinking that'd be caused by late IVC??
Matt T wrote: Would that cause the deeper decompression pocket? I'm thinking that'd be caused by late IVC??
Ummmmmm, sure? :silly: I honestly have no idea. I'm terrible about using my in-cylinder transducer. Few times a year, maybe.
Lol. We'll save that one for later.Matt T wrote:
Pics with the timing cover removed :lol:Chad wrote: What would you like to see, next?
Here you go:Or 'scoping CKP and CMPs would be a less invasive option if you can find a known good.
Unknown/Suspect Cams and Crank
eScope File
drive.google.com/open?id=1gFusaVM-E0h1E1mv5iYfXIY4w00puCmO
Known Good (Downloaded from FB courtesy of Justin Miller)
PicoScope 6 Software
www.picoauto.com/download/software/sr/Pi...tomotive_6.14.25.exe
We'll get to those later, too.Tyler wrote: VVT PIDs might be fun? But probably not necessary. If the intake were truly that late, there'd be more than just a P0300.
RC - Voltage Inverted
NPS in Intake Manifold
NPS in Exhaust Tailpipe
Intake on B1 is definitely late compared to B2. Exhaust cams seem to be in time. Why is this not setting timing codes? :huh:
- Matt T
Tyler wrote: Annnnnnnd there goes my cam lobe/follower idea. :lol:
It definitely looks a bit late but only looks to be a few degrees. I was expecting 30*ish......
Here you go, Tyler.
Scan Data
drive.google.com/file/d/1IGgWV7FaVtfS7B8...TOt/view?usp=sharing
But I did notice something about the camshaft behavior. Dunno if it matters or not. :huh: Using the cam/crank PIDs, with the phasers parked, intake #2 is always a positive value, while all other cams are negative.
Plus, intake #1 is always about five to seven degrees retarded of #2. Even when the intake cams are being advanced, intake #1 is always behind #2 by about the same amount. Maybe just a little bit of stretch in the chain?
Can't say that'd cause a P0300, though.
- Matt T
Matt T wrote: Crank "Out of Sync" :huh: I downloaded that escope software. CKP trace looks kinda rough.....
I couldn't figure out how to open Chad's capture with it.
- Matt T
Tyler wrote: I couldn't figure out how to open Chad's capture with it.
It'd only let me poke around in Demo mode.
As well as the way Matt T showed, you can also load files from the Measure and Deep Record mode. This is where any zooming and cursor work is done.
Can't say I'm good at it yet, but I'm getting somewhere. The CKP/CMP would seem to agree with the scan data about their being about a five degree difference between the intake cams. Still not sure that adds up to a rando miss, though.
I reached out to Weycraze, as he has steered me in the right direction a couple of times before. He recommended taking a frequency of the crankshaft to see if we could see a Bank-to-Bank contribution difference. A great idea! I used the CKP/Misfire function of the eScope to plot crank frequency, with the cylinders labeled. However, the results leave me more confused about what is going on than before.(on a side note, the ATS CKP/misfire function is awesome!)
The Crank Frequency doesn't look pretty. However, I can see no rhyme, or reason, for the frequency changes. They seem to be all over the place. I, finally, decided to perform a Cam/Crank relearn, clear codes, and go for a long test drive to get a fresh look at mode 6. The thing performed beautifully. It didn't miss a beat. Mode 6 showed no misfires over a 50 mile test drive. No loss of power. Fuel trims look great. Suddenly, the vehicle seems fine. However, scan data VVT pids look the same. :woohoo: It, still, says "Crank out of Sync". Scan Data, still, shows Bank 1 cam/crank difference of -3.5°, and Bank 2 showing +2.5. :dry:
I recaptured Cams/Crank correlation, and can still see a 5° advance on the Bank 2 intake but, haven't compared it to the first capture, yet.
Right now, it is running so good that I can't justify fixing it. :ohmy: :sick: :blink: :woohoo:
Tyler wrote: Still not sure that adds up to a rando miss, though.
Preamble:
To be clear, I never experienced a miss. I DID notice a lack of power, and could smell sulfur/rotten eggs on heavy acceleration, though. The customer complaint was CEL on, and running rough. My junior tech had the first go at it. He said that it was counting misfires on 2, 4, and 6. When I took over, it was running, kind of, okay? Just a bit of power loss, and sulfur smell on heavy acceleration.
I thought I knew where this one was going, but ended up clueless.
