No Start with Crank Sehsor connected
  • alanhoyt
  • alanhoyt's Avatar Topic Author
7 years 11 months ago #25215 by alanhoyt
No Start with Crank Sehsor connected was created by alanhoyt
Infiniti M56x VIN # JN1AY1AR9BM570450
Car lot replaced the engine and could not get it started. Sets a CKP code. With the Crank Sensor unhooked it will crank for a bit and then start and run but not the best. Shuts off at around 53 mph.
I am an Automotive Technology Instructor for two high schools and my approach is to look at everything on the vehicle through current flow and scope patterns. I have looked everywhere I can think of for a scope pattern showing cam/crank and hopefully cylinder pressure waveform on this engine but I have not found any that I thought was actually correct for this 5.6. Nissan makes a 5.6 that doesn't have variable valve timing on all 4 cams but this one does and I am pretty sure the crank sensor pattern should be different as well.
Any chance you can get me the waveform?
The car lot is adamant that the engine is out of the exact year make and model plus they replaced the flywheel and ordered it by VIN from Infiniti so I am leaning towards an actual internal timing issue in the salvage yard engine but without a known good scope pattern I feel it is too intense of a diagnostic process to work through with my highschoolers.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
7 years 10 months ago #25226 by Dylan
Replied by Dylan on topic No Start with Crank Sehsor connected
Moved your topic to the repair section so it gets more views.
7 years 10 months ago #25245 by Tutti57
Replied by Tutti57 on topic Re:No Start with Crank Sehsor connected
We just had a xterra in our shop and the guy next to me had just replaced the transmission and then it wouldn't start. Had crank ps codes. The new flywheel was bent slightly. It also ahd the long cranks until the cps took over then ran poorly.
7 years 10 months ago #25262 by Tyler
Replied by Tyler on topic No Start with Crank Sehsor connected
Did you happen to post about this vehicle in the TechHelp section on iATN? Because I think I found it. :lol:
Don't have any known good waveforms for this engine. :( But I agree that you're looking at a mechanical timing issue. Classic Nissan/Infiniti symptom.
7 years 10 months ago - 7 years 10 months ago #25264 by juergen.scholl
Replied by juergen.scholl on topic No Start with Crank Sehsor connected
Sorry, no reference waveform here either...
Nevertheless, try to get your hands on an USB autoscope (that is the name of an engine analyzer/osciloscope) and run the provided Px and CSS scripts. You will be able to identify mechanical timing issues without reference waveform.
Her is a link to ho the Px script works.
Last edit: 7 years 10 months ago by juergen.scholl.
7 years 10 months ago #25268 by Desmond6004
Replied by Desmond6004 on topic No Start with Crank Sehsor connected
I had a Nissan in the shop a while ago that had the transmission replaced and would no longer start. After quite a bit of back and forth support I torqued the mounting bolts properly and it started and ran for a while then died. After doing a high frequency scope pattern of the crank sensor it could be seen that the crank signal was getting cut into smaller sections due to magnetic interference. I was told about a Nissan with a similar issue that would not start and had one bolt missing from the transmission housing after an engine swap - simply pushing a piece of metal in the empty hole got it started - it caught the magnetic interference that was going in front of the crank sensor.
With the vehicle I was working on the only way to get around the magnetic interference issue was to grind the crank sensor hole bigger, wrap a piece of thin metal around the sensor and give it a good earth on one of the mounting bolts - after that it started and ran perfectly.
The following user(s) said Thank You: kevinedward1234
Time to create page: 0.322 seconds
