BMW X5 E70 3.0si N52k engine 2007
- naros812000
8 years 9 months ago #17545
by naros812000
BMW X5 E70 3.0si N52k engine 2007 was created by naros812000
Dears,
I would like to get info regarding the above mentioned BMW. The issue with it is that the car consumes oil. Even the oil can get passed to Intake manifold and makes the MAF oily. I replaced the PCV valve which BMW calls it Oil Seperator.
Can anyone guide me how to fix this problem? or what is the the cause of this issue?
Photos attached that shows oil leakage
8 years 9 months ago - 8 years 8 months ago #17548
Replied by Andy.MacFadyen on topic BMW X5 E70 3.0si N52k engine 2007
It looks like the crankase is pressurising from excessive piston ring blow-by. Although these engines used the "Alusil" cyl#inder bore coating rather than the highly problematic "Nikasil" cylinder bore coating it is always going to more prone to bore wear than a conventional cast iron or chrome plated cylinder bore. I understand that any reconditioning of these engines is really only a manufacturer only job.
Last edit: 8 years 8 months ago by Andy.MacFadyen.
- Dylan
- Belgium, Europe
- Thank you received: 327
8 years 9 months ago #17555
by Dylan
Replied by Dylan on topic BMW X5 E70 3.0si N52k engine 2007
I'm moving this to repair section guys.
- bmw master tech
8 years 6 months ago #19846
by bmw master tech
Replied by bmw master tech on topic BMW X5 E70 3.0si N52k engine 2007
sound like a bad crankcase valve
