subaru 2.5 ej25 engine.misfiring at idle only.
  • cyrus.nk
  • cyrus.nk's Avatar Topic Author
10 years 3 months ago #399 by cyrus.nk
I have Subaru legacy misfiring at idle but when i press the gas ,its run fine.no trouble code at all.checked ignation coil,sparks plugs,injector nozzles and are ok.nids some help!
  • RobBrown
  • RobBrown's Avatar
  • Glad to be here!
10 years 3 months ago #407 by RobBrown
Replied by RobBrown on topic subaru 2.5 ej25 engine.misfiring at idle only.
Hi there,
Do you have access to your fuel trim numbers? Giving us an idea of what the ST and LT numbers are doing at idle and 2500 rpms would provide us with some very relevant information. Very well could be a vacuum leak of some sort...though I've also seen a blown head gasket leaking coolant internally cause idle misfires, particularly on first start when the engine is cold.
Thanks!
10 years 3 months ago - 10 years 3 months ago #420 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic subaru 2.5 ej25 engine.misfiring at idle only.
Thinking old school, have you done a compression test? A leaking exhaust valve will smooth out at higher RPM.
Last edit: 10 years 3 months ago by Andy.MacFadyen.
  • cyrus.nk
10 years 3 months ago #424 by cyrus.nk
Replied by cyrus.nk on topic subaru 2.5 ej25 engine.misfiring at idle only.
Can see ltft and stft but i see a/f learning 1 % and fuel correction -23% at idle.air fuel sensor # 1 0.75 hope this is equivalence ratio.lambda sensor voltage 2.5 to 2.3 and sometimes 0.95 to 3.0 volts.
  • RobBrown
  • RobBrown's Avatar
  • Glad to be here!
10 years 3 months ago - 10 years 3 months ago #430 by RobBrown
-23% fuel correction at idle...so the computer is taking fuel away. At idle are you smelling fuel at the tail pipe? I suppose I'd want to know if this truly is a rich condition or if it's a false rich condition. If there's a strong smell of fuel, particularly at cold start up (when the engine is in open loop), it's likely that there really is an issue with the fuel delivery system (for example, a ruptured fuel pressure regulator that's leaking fuel into the intake). If there is no smell of fuel from the pipe, I'd look at your AF and lambda's and try to prove that they're responding properly, namely by creating a big vacuum leak and watching to see that the voltage readings drop really low.
Also, does that fuel correction number do when you raise the rpms to 2500-3000? Does it stay really negative or does it get closer to zero?
Checking the fuel pressure regulator on these engines is really easy. it sits on the fuel rail below the air intake duct and has a vacuum line attached to it. Unplugging that vacuum line when the engine is running and looking for fuel spitting out will tell you if the diaphragm in the regulator is ruptured. A quick, easy to perform test.
Rob
Last edit: 10 years 3 months ago by RobBrown.
  • cyrus.nk
10 years 3 months ago #433 by cyrus.nk
Thank u guys!am going to check that.
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
10 years 3 months ago #437 by ScannerDanner
Replied by ScannerDanner on topic subaru 2.5 ej25 engine.misfiring at idle only.
Andy.MacFadyen wrote: Thinking old school, have you done a compression test? A leaking exhaust valve will smooth out at higher RPM.
agree with Andy, your symptoms describe a mechanical problem to the letter
Don't be a parts changer!
10 years 3 months ago #462 by Tyler
Another vote for mechanical problem. Personally seen these engines burn valves, or have sticking exhaust valve guides.
A relative compression test would give you great direction, before pulling the plugs and doing compression testing. Even if you don't have a scope, you can disable fuel and just listen to the engine cranking.
The Jeep 4.0L timing problems video has a perfect example of this. Listen to the engine around 7:42.
If you hear something like that during cranking, then I'd say you can move directly to compression and leak down testing.
  • cyrus.nk
10 years 3 months ago #481 by cyrus.nk
Thank u all.I have fixed the problem,was stuck open egr valve.now why the pcm was not seeing that?
10 years 3 months ago #525 by Tyler
Aw man, I was way off! lol
Still very happy you came up with a fix, sir. What led you to checking the EGR valve?
In retrospect, the fuel trims being way negative could have steered us towards a stuck open EGR, oh well. Why the PCM didn't pick up on that would probably depend on how it monitors the EGR position, and what the code set criteria is. If this uses a potentiometer in the EGR valve, then it may only code when the position exceeds a certain point. Knowing what a known good closed position value is might be useful for the future.
10 years 3 months ago #591 by Noah
Hey Cyrus, did you happen get a look at the fuel trim numbers after the fix? I'd like to know if if you still have excessive negative trims. It would really help for a discussion going on in the Book Questions and Discussion section. Thanks man, good job on the fix by the way.
Time to create page: 0.343 seconds
