P2127 Accelerator pedal position sensor to circuit low voltage
- Columbus450
- Topic Author
- Thank you received: 14
4 years 8 months ago - 4 years 8 months ago #33135
by Columbus450
07 chevy avalanche
This is an intermittent issue I have scoped out the accelerator pedal and tps sweep all looks good , Engine goes into reduced power mode problem occurs after hitting bumps, I have checked a wire harness going to the throttle position sensor no issues , I'm leaning towards changing the app But I want to be 100% sure the APP 2 didnt look as perfect as app 1 on scope , but i could Never catch it acting up only until I drive it and hit bumps above picture is a snapshot of tps Desired not Matching the actual percentage of throttle ideas?
Sent from my SM-N960U using Tapatalk
Last edit: 4 years 8 months ago by Columbus450.
- Columbus450
- Topic Author
4 years 8 months ago #33136
by Columbus450
Replied by Columbus450 on topic Re:P2127 Accelerator pedal position sensor to circuit low voltage
- Columbus450
- Topic Author
4 years 8 months ago #33147
by Columbus450
4 years 8 months ago #33149
by jreardon
Replied by jreardon on topic P2127 Accelerator pedal position sensor to circuit low voltage
In PID APP2(V) the min - max range reads 0.06-2.06. The min is too low I think. The condition for setting the dtc is "app sensor 2 voltage is less than 0.325 volt for more than 0.4 seconds"
Tried the tap test, surely that must make the app sensor act up?
The following user(s) said Thank You: Columbus450
- tim.smith1
- Thank you received: 61
4 years 8 months ago #33155
by tim.smith1
Replied by tim.smith1 on topic P2127 Accelerator pedal position sensor to circuit low voltage
With drive by wire I always make sure to take the throttle body off and clean it real good before replacing any parts
- Columbus450
- Topic Author
4 years 8 months ago #33156
by Columbus450
(null)
Your right i totally missed that ,did the test again and put my scope on app 2 and i captured it dropping out well below. .325 volts with me applying the accelerator with my hand rapidly koeo
2 weeks 4 days ago #65519
by Johnny2cv
Replied by Johnny2cv on topic P2127 Accelerator pedal position sensor to circuit low voltage
Hi, did you find the solution to your code p2127? I’m having the same exact problem after hitting a bump on my 07 avalanche and it’s driving me crazy. Thank you
Time to create page: 0.252 seconds
