1997 buick lesabre series 2 intermittent crank no start.
3 weeks 1 day ago - 3 weeks 1 day ago #65481
by Jzap574
1997 buick lesabre series 2 intermittent crank no start. was created by Jzap574
So last year I bought a 1997 buick lesabre custom with about 76,000 miles. Drove it home, about 500 miles no problem, I had the freon filled because it was low. Shorty afterwards, it starting cutting off. So I had the alternator changed, drove it for a couple miles and stopped at o reilly s for a couple minutes. Came outside and it was cranking but it wouldn't start. We changed the fuel pump and still couldn't get it to start. I literally left the car there for about a week out of frustration. I came back and it started right up. An electronic mechanic told me it was the alternator harness . So he rewired it to stay on but the problem persist. This happens when the car is at operating temp. Also I live in south texas so during the high heat/summer is when the problem starts. It runs good when I'm on the highway ,but when Im driving in the city/stop and go or idling at heavy traffic red lights it will turn off. Please help, running out options. I bought this car thinking this motor the 3800's were fairly simple to fix but I was mistaken.
Last edit: 3 weeks 1 day ago by Jzap574.
3 weeks 15 hours ago - 3 weeks 15 hours ago #65487
Replied by Chad on topic 1997 buick lesabre series 2 intermittent crank no start.
My first thought is a dirty throttle-body. If it gets too dirty, it will not allow enough air past the throttle plate, at idle.It runs good when I'm on the highway ,but when Im driving in the city/stop and go or idling at heavy traffic red lights it will turn off.
Last edit: 3 weeks 15 hours ago by Chad.
- IaintYerPaw82
3 weeks 13 hours ago #65491
by IaintYerPaw82
Replied by IaintYerPaw82 on topic 1997 buick lesabre series 2 intermittent crank no start.
i had one do this a couple weeks ago, it ended up being the crank sensor. Intermittently wouldnt crank after getting hot, let it cool off and it would crank again. i had to use a labscope to verify i wasnt getting one of the 2 crank signals to the Ignition Control Module. Replaced the crank sensor and it was fixed.
3 weeks 12 hours ago #65492
by Jzap574
Replied by Jzap574 on topic 1997 buick lesabre series 2 intermittent crank no start.
Appreciate the advice, ill take look thank you.
6 days 1 hour ago #65601
by Jzap574
Hey , I cleaned the throttle body it was caked up with carbon, but I managed to get it all off. After wards I had suction when I took off the oil cap. A friend suggested changing the pvc valve and i noticed it didn't have the spring inside. After changing it and putting the spring in it the suction went away but the idling issue continues when I'm parked. If I turn off the a/c of the recirculation button it stops. Any suggestions?
- Hardtopdr2
- Thank you received: 141
6 days 9 minutes ago - 6 days 5 minutes ago #65602
by Hardtopdr2
Replied by Hardtopdr2 on topic 1997 buick lesabre series 2 intermittent crank no start.
what size engine does it have? 3.4, 3.8 etc?
Some questions are to rule out possible internal compressor failure causing a/c compressor to lock up and stall vehicle considering this happened after recharging a/c system.....
Does it start at operating temp with a/c off?
What codes if any are setting?
What idling issue are you having with the a/c on? idles up or down etc?? possible failing Idle air control valve or egr valve if equipped
Have you had the a/c professionally serviced or just topped off yourself?
What are the system pressures?
1. rest pressure readings with a/c off high and low side and ambient air temp reading preferably cold engine or a/c not running the last 30 minutes before taking this reading?
2. running pressure both low side and high side readings with ambient air temp and engine temp?
3. operating pressures when no start / stall happens with ambient air temp and engine temp?
Also take the spring out of the pcv valve. lets not create additional problems to this issue.
Last edit: 6 days 5 minutes ago by Hardtopdr2.
