Registering Replacement Batteries to Vehicles w/Scantool
1 month 3 weeks ago #65035
by rockp2
Registering Replacement Batteries to Vehicles w/Scantool was created by rockp2
Today I learned something new (to me) about batteries having to be registered with scantool when being replaced on many newer vehicles. From what I'm reading a rule of thumb is if the vehicle has auto start-stop the replacement battery needs to be registered so the charging system charges the battery correctly to prevent over/under charging. If I'm understanding correctly the vehicle charging system adjusts based off if age if battery.
A video stated the battery has to be exact to the one being replaced (meaning capacity, etc). Is this indeed true? You can't replace battery with larger capacity, aH, etc and register the battery as such to the vehicle?
- Thank you received: 969
1 month 3 weeks ago #65055
Replied by Noah on topic Registering Replacement Batteries to Vehicles w/Scantool
That's a good question, I imagine it is different from car to car.
There are plenty of shops willy nilly dropping batteries in cars, I wonder what the consequences of failing to register the new battery or using the wrong battery could be for the car owner.
1 month 3 weeks ago #65057
by rockp2
Replied by rockp2 on topic Registering Replacement Batteries to Vehicles w/Scantool
From what I'm reading, if I'm grasping correctly, it's a "smart" charging feature that uses the age from the battery register to lower the charge rate as the battery as the battery gets older. I don't think it's doing any type of measuring battery capacity to determine charge. It's based off time and uses as default the original battery capacities, etc...similar to an oil change percentage using crank revolutions.
It looks like it started with BMW several years ago and is quickly being adopted. Sounds like newer Chevy all have it now (that have the "smart" systems). Seems like you'll know if the car needs it done if your scantool (with current updates) has the selection choice. I'll try to find the video I stumbled across that led to me researching more.
Doubt the parts stores are going to be offering battery replacements on those cars for the customers.
1 month 3 weeks ago #65058
by rockp2
Here's the video that led me down the rabbit hole.
1 month 3 weeks ago #65059
by rockp2
A link to a better explanation than I gave:
www.batteriesplus.com/blog/power/car-battery-registration
- ontheriver
- Thank you received: 16
1 month 3 weeks ago #65060
by ontheriver
Replied by ontheriver on topic Registering Replacement Batteries to Vehicles w/Scantool
Auto parts stores are starting slowly around here to offer the service. Give it time. I did ask about scanners to retract the rear brake calipers for a brake service and got nowhere, that I hope they will catch up on also
1 month 3 weeks ago #65062
by rockp2
Will I be able to change the parameters of the battery in the ECU if/when I run into a car that requires the registration?
Where are you located if I could ask?
Are they able to adjust parameters if the parameters of the replacement battery are not the same as original? That's my main question, if it's accurate that you cannot use a battery that's not exactly the same as original (not referring to brand of battery).Auto parts stores are starting slowly around here to offer the service. Give it time. I did ask about scanners to retract the rear brake calipers for a brake service and got nowhere, that I hope they will catch up on also
- ontheriver
1 month 3 weeks ago #65064
by ontheriver
I'm in upstate n.y., a stone's throw from Saratoga springs. You bring up a good question, I Will ask them what tool is being used, hopefully a quality one
1 month 3 weeks ago #65080
by aholco
Replied by aholco on topic Registering Replacement Batteries to Vehicles w/Scantool
Hey there, I work on Porsche and other German cars daily. I use scan tools whenever swapping a battery on the newer cars that take the battery programming. My Autel prompts me for the type of battery, Ah rating, part number and serial number. On cars that have a lot of electrical consumers we will sometimes upgrade the battery, so the Ah rating is changed. I have not tried swapping battery types yet but there are options, for example flooded, AGM, or lithium. The scan tool will accept any combination of characters for the part number and serial number of the battery. I believe the most important is it gets the right type and Ah rating selected when replacing the battery.
1 month 3 weeks ago #65084
by rockp2
Thanks very much for the answer aholco. You answered my question exactlty. I was just finding it hard to grasp that to register the battery you could only use original battery parameters.
- AustinPearson
1 month 1 week ago #65280
by AustinPearson
Replied by AustinPearson on topic Registering Replacement Batteries to Vehicles w/Scantool
Thank you so much for the link.
Time to create page: 0.244 seconds
