Leak checking A/C
- gmtech2012
- Topic Author
1 month 11 hours ago #65416
by gmtech2012
Leak checking A/C was created by gmtech2012
I've seen several videos where you check the r- 134a systems for leaks using shop compressed air. And in the last few weeks I've used that procedure myself and gotten a lot of success. My question is, can we use the same leak check procedure on an r-1234yf system? I can purchase a manifold gauge set that will hook up to these systems but I want to know for sure if it can be done just like the 134a systems?
- Thank you received: 969
4 weeks 1 day ago #65421
Replied by Noah on topic Leak checking A/C
Technically, you shouldn't even do it with R134a systems. I do, and will continue to do so, but nitrogen or CO2 are favored over shop air.
4 weeks 6 hours ago #65426
Replied by Tyler on topic Leak checking A/C
Like Noah said, you absolutely can do the same check with shop air. There's little difference between that and a system that's already leaked all the refrigerant out. Should you? No, IMO, but that shouldn't stop you if you think it's worthwhile.
Some techs swear off refrigerant detectors, but I love mine. To each their own!
Time to create page: 0.221 seconds
