1989 F-150 4.9L No Spark!
6 years 7 months ago #13301 by seagiant
Hi,
I have a FORD 1989 F-150 4.9L pick up.
The truck just died and will not start.
Using test procedures from Haynes and the Internet I first tested the spark from the coil tower with my test light and there is no spark.
I made a 12V led light to test the signal on the ICM after testing for power and ground at the connector, all was good!
Oh yes I tested the computer relay also and put in a new one.
Trying to not leave anything out.
When the ICM showed good I just bought a new MOTORCRAFT Ignition coil and put it in. (the old one had 300,000 miles on it!)
Put in the new ignition coil and sometimes I get spark sometimes not?
Checked the signal wire from ICM to IC and it has continuity?
Everything should be good but I'm now at a loss on what to do next???
Any ideas on where to go next would be appreciated!!!
6 years 7 months ago #13303 by cheryl hartkorn
are you getting 12 volts at one of the coil wires? check it under a load. id start there.
6 years 7 months ago #13311 by seagiant
Replied by seagiant on topic 1989 F-150 4.9L No Spark!
Hi,
Thanks!
I just started completely over in my testing.
Checked the IC for power and it is good.
Then checked it for a pulse signal and there was none.
Went to the ICM....ground and power is good, but...
Now no PIP Signal !
pulled the spout and engine does not crank.
This is confussing as I had the PIP signal before, but???
I'm going to see if I can rebuild a OEM ford dizzy with new MOTORCRAFT PIP sensor and ICM.
The dizzy in it now is a OEM junkyard find and worked for awhile I guess.
I don't know what else to try, need to get this going!
6 years 7 months ago - 6 years 7 months ago #13338 by seagiant
Hi,
Just finished rebuilding a JY FORD OEM dizzy, with new MOTORCRAFT PIP Sensor and ICM!
Try to get it in tomorrow and see if that makes a difference? (see if I can get a spark at coil tower???)
I have tried to test going by established guide lines, including watch ScannerDanner on U-Tube!
In this adventure though, the Cap and Rotor, now Dizzy rebuilt and the Ignition coil is new!
This truck has close to 300,000 miles on it so I'm not overly worried about buying parts, but would like to know something is bad before hand, if possible?
Last edit: 6 years 7 months ago by seagiant.
6 years 7 months ago #13358 by seagiant
Hi,
Well, not a lot of feed back here???
Thought this would be the place to get some troubleshooting advice???
6 years 7 months ago #13359 by cheryl hartkorn
been busy with work. you said you put a new cap/rotor and distributor in with the module is new and still no spark??
6 years 7 months ago #13360 by seagiant
Hi,
No, rebuilt it last night, all good there.
Will get it in today hopefully but worried if still no spark after that....
Where to go next?
This is a weird situation cause it seems that the ICM actually tested good then replaced coil as per troubleshooting guide....
Then ICM retested and now testing bad?
I don't know, wondering about the EEC/computer?
Guess I could pull it and look for bad caps?
Not getting a lot of help on this except other people on other forums giving their guess on what part to change which is not what I'm looking for!
I can do that on my own!
I'll put in the new rebuilt dizzy and see what happens!
6 years 7 months ago - 6 years 7 months ago #13371 by seagiant
Hi,
Put in the new rebuilt dizzy and got nothing?
I retested the coil, I got power on the positive and no flashing on the signal.
I did an ohm's test on the signal wire from the coil to the #5 signal coil ICM terminal and have continuity???
I back probed the #5 on the ICM and got 5 volts on my vom meter while cranking?
This is all GOOD by the test but I have no spark at the brand new coil?
My battery is now dead from the testing and I'm recharging it.
Oh yea, all of this is going on in a parking lot where I work so I'm having a ball!
If ANYONE here has any ideas, I'm all ears!
Probably pull the computer next as this is not going well by the book of testing and finding solutions!
6 years 7 months ago #13372 by cheryl hartkorn
could try tapping the signal wire to the coil to ground see if it sparks.
6 years 7 months ago #13373 by cheryl hartkorn
NEW means nothing
6 years 7 months ago #13375 by cheryl hartkorn
have you seen this article??
easyautodiagnostics.com/ford/4.9L-5.0L-5...ition-module-tests-5
i would definetly check the pip sensor. i havent messed with one of these in 15 years or so
6 years 7 months ago #13377 by seagiant
cheryl hartkorn wrote: could try tapping the signal wire to the coil to ground see if it sparks.
Hi,
So, I understand the ICM gives the ground to the ignition coil off and on from the PIP Sensor, to make the coil "spark"?
If grounding that line at the coil, makes the coil spark then there HAS TO BE a short in that wire even if I get continuity???
Thanks for the help!
I do appreciate it, but I'm now a little aggravated with this!
I don't think any thing was wrong with the JY Ford dizzy but I have to follow the trail and try to make it better as I go.
This problem COULD of been anything I have already renewed???
I feel I'm missing something and it is something stupid, but I don't know what?
6 years 7 months ago #13380 by cheryl hartkorn
grounding it with a testlight on the control wire should make it spark. it just proves its a good coil
6 years 7 months ago #13384 by seagiant
Hi,
I was going to ground the control wire with a jumper and T-pin, then....
take a test light and see if a spark will jump to an air gap at the test light.
When I turn it over.
If it sparks, does that mean it is NOT getting the signal from the ICM?
Right now, EEC Relay, Ignition Coil, AND Dizzy are all new MOTORCRAFT Parts!
I feel there is a short somewhere or a computer problem?
Any ideas on this? Any other ideas at all? Any experience with this???
Not getting a lot of feed back???
6 years 7 months ago #13390 by GypsyR
Replied by GypsyR on topic 1989 F-150 4.9L No Spark!
I'd still be suspecting the ICM at this point simply because I've seen so many fail. Try looking at some tests here though-
easyautodiagnostics.com/ford/4.9L-5.0L-5.8L/index-of-articles-1
6 years 7 months ago #13400 by seagiant
GypsyR wrote: I'd still be suspecting the ICM at this point simply because I've seen so many fail. Try looking at some tests here though-
Hi,
Thanks, those are the test I've been using!
Going to go back to square one and start over again.
Battery is charging back up and will try again with it fully charged.
As a side note, I ran this truck for 25 years and never had a coil problem, ICM problem, or a PIP sensor problem???
Thanks again!
6 years 7 months ago #13412 by Tyler
Replied by Tyler on topic 1989 F-150 4.9L No Spark!
Hey seagiant! Can you bring me up to speed on your testing so far? I just got done with another EEC-IV problem at work, so a lot of this stuff is fresh in my head. :lol:
6 years 7 months ago #13413 by seagiant
Tyler wrote: Hey seagiant! Can you bring me up to speed on your testing so far? I just got done with another EEC-IV problem at work, so a lot of this stuff is fresh in my head. :lol:
Hi,
I think I may have stumbled on a clue.
I think maybe I have a short in the RF noise capacitor....
And THAT is keeping the coil from sparking???
I'm going to look under the coil and do some tracing and see if that is it?
Thanks for the help, if this is not it, I will get back!
6 years 7 months ago #13415 by Tyler
Possible? The only way that could be true is if it was a direct short, causing the fusible link to burn, and interrupting power to the coil and ICM.
Normally, the engine WILL run without the capacitor. So, if you have any doubts, you can disconnect it for now.
The following user(s) said Thank You: seagiant
6 years 7 months ago #13416 by cheryl hartkorn
you said you dont have a pip signal. that comes from the distributor. sounds to me the "new" distributor might have a bad pip. do you have a scope??
Time to create page: 0.381 seconds
